Rope Position Inconsistencies over Network - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Rope Position Inconsistencies over Network (/thread-90.html) |
Rope Position Inconsistencies over Network - PhantomBadger - 30-08-2017 Hi all, Im currently working on a networked app with ObiRope, and we have a slight issue wherein the rope has slightly inconsistent positions when networked, now a slight difference is ok, but the difference at the edge of the rope - where it is connected to an object, are quite drastic, often having the rope stick out (See Image below) ![]() For reference, my rope set up is structured as follows: ![]() A - End-point Object A (Connection A in Hierarchy) B - End-point Connector Object A (Point A in Hierarchy) C - Obi Rope [d]D[/d] - End-point Connector Object B (Point B in Hierarchy) [e]E[/e] - End-point Object B (Connection B in Hierarchy) Now, my original concern was this was an issue with my network solution. My current solution is to network the positions of the used particles in the ObiRope, Getting and setting them into Oni on each end. This was due to a client requirement to have 1-1 Rope Positions across client and server. Used by the Server to assign positions to the network: Code: /// <summary>Used by the client to get positions from the network Code: /// <summary>With this in mind what could be causing this difference? Especially such a major difference at each end of the rope? My initial thought is it is the rendering portion of the set up, but I'm not sure. Thanks! EDIT: From some further investigation, using Handles seems to be 100% fine, but then I cant move the other end of the rope by using the first, so I would assume the issue is with the pin constraints? RE: Rope Position Inconsistencies over Network - PhantomBadger - 30-08-2017 All Fixed! Should anyone else be having issues with the pin constraints like myself, my issue was that the anchor and the particles both had a mass of 0.1, meaning there wasnt a lot of influence between them. The colliders for the anchor were also disabled on the clients, causing the constraints to not work at all! |
