Help I put the water in the cup. The fluid motion does not stop. - Printable Version
+--- Thread: Help I put the water in the cup. The fluid motion does not stop. (/thread-866.html)
I put the water in the cup. The fluid motion does not stop. - psk_1603 - 03-02-2019
So I set the 'sleep threshold' to 1.
It was like 30 seconds after the video.
What should I do to stop naturally?
RE: I put the water in the cup. The fluid motion does not stop. - josemendez - 04-02-2019
Try increasing the solver's "damping" parameter a bit, or apply some more friction to the cup's collision material. Having frictionless surfaces and no energy dissipation can lead to endless motion. Also, increasing the amount of density iterations will help reducing the amount of particles that rise to the surface due to pressure building up at the bottom of the cup.
