ObiRope 2D + threaded rings - Printable Version
+--- Thread: ObiRope 2D + threaded rings (/thread-841.html)
ObiRope 2D + threaded rings - oraspec - 28-01-2019
Hi guys,
I am looking for a solution to have 2D thread with ringsĀ on it. Rings should not be attached to specific particle. It should move on a thread back and forth influenced by real physics/gravity. Can you advise whether it is possible to realize it with ObiRope for 2D without programming the threaded rings physics?
Thanks in advance.
RE: ObiRope 2D + threaded rings - josemendez - 28-01-2019
(28-01-2019, 07:47 PM)oraspec Wrote: Hi guys,
Thanks in advance.
You could do this in Obi, however it would not be very robust as ring sliding back and forth would rely exclusively on collision detection. An ad-hoc system would probably be simpler and more robust.
