Build errors with latest Unity - Printable Version
+--- Thread: Build errors with latest Unity (/thread-817.html)
Build errors with latest Unity - Bluerex - 14-01-2019
With the current asset store version of Obi Rope, I get build errors. I created a new, empty project, imported Obi Rope, then opened the solution and did a build, and I get the following errors:
Error    CS0308    The non-generic type 'Queue' cannot be used with type arguments    Test    F:\Unit Projects\Test\Assets\Obi\Scripts\Actors\ObiBone.cs    104
Error    CS0246    The type or namespace name 'Stopwatch' could not be found (are you missing a using directive or an assembly reference?)    Test    F:\Unit Projects\Test\Assets\Obi\Scripts\Coroutines\CoroutineJob.cs    93
Error    CS0006    Metadata file 'F:\Unit Projects\Test\Temp\UnityVS_bin\Debug\Assembly-CSharp.dll' could not be found    Test.Editor    F:\Unit Projects\Test\CSC    1    Active
Any tips on how to fix this?
RE: Build errors with latest Unity - josemendez - 14-01-2019
(14-01-2019, 06:39 PM)Bluerex Wrote: Hi,
Cannot reproduce this on Unity 5.6, 2017.4 or 2018.2.
Stopwatch is defined in System.Diagnostics; and CoroutineJob.cs includes it.
Queue<T> is defined in System.Collections; and ObiBone.cs includes it.
What is your target platform and project settings? (specially Scripting runtime and API compatibility level)
RE: Build errors with latest Unity - Bluerex - 14-01-2019
(14-01-2019, 07:29 PM)josemendez Wrote: Hi,
My unity version is 2018.3.02f (the latest).
My scripting runtime is .NET 4.x
My API compatability level was .NET 2.0, but I also tried .NET 4.X and it still didn't work.
RE: Build errors with latest Unity - ibbybn - 14-01-2019
(14-01-2019, 10:03 PM)Bluerex Wrote: My unity version is 2018.3.02f (the latest).
I'm using 2018.3.1f1 with no problems here.
Must be something else.
Btw 2018.3.02f is not the latest, it's a half year old beta. Guiño
(14-01-2019, 10:36 PM)ibbybn Wrote: I'm using 2018.3.1f1 with no problems here.
Maybe that's the issue then - I'll get the latest from the site. Thanks!
(14-01-2019, 10:43 PM)Bluerex Wrote: Maybe that's the issue then - I'll get the latest from the site. Thanks!
Just to update this thread - Updating unity didn't help, but updating Visual Studio 17 to 15.9.5 worked.
