2D Rotate Z-Axis Fluid falls Out - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: 2D Rotate Z-Axis Fluid falls Out (/thread-728.html) |
2D Rotate Z-Axis Fluid falls Out - p3gamer - 25-10-2018 I have a cup sprite with an EdgeCollider2d attached. After Obi Fluid particles are in the cup, I then rotate the cup (z-axis) (about 5-10 degrees) and I notice that the particles fall out. Is there a setting that I need to modify to prevent this? Thank you. |
