Help Using Obi Fluid for Mobile Slime Simulation - Printable Version
+--- Thread: Help Using Obi Fluid for Mobile Slime Simulation (/thread-680.html)
Using Obi Fluid for Mobile Slime Simulation - arrnav96 - 07-09-2018
I’ve been considering purchasing your asset “Obi Fluid” for making a slime simulation game for android. Before purchasing I just want to be sure, can I use this asset to create something like this? I want to be able to represent a finger pressing on a “goey” fluid on screen so user can interact with the fluid. The fluid should also be able to reform to it’s original shape very slowly, just like real slime.
Is this possible? Will definitely purchase your asset immediately if so. Thanks.
RE: Using Obi Fluid for Mobile Slime Simulation - josemendez - 07-09-2018
(07-09-2018, 02:33 PM)arrnav96 Wrote: Hi,
The reference gif does not show a fluid. That is an elastic solid, simulated using a textured rectangular mesh with springs in every edge.
So no, Obi Fluid is not intended for this kind of simulation. You could achieve it with Obi Cloth, however. A simple textured rectangular cloth with very low stiffness should do.
RE: Using Obi Fluid for Mobile Slime Simulation - arrnav96 - 07-09-2018
(07-09-2018, 03:43 PM)josemendez Wrote: Hi,
Hi, thanks for the reply. So before I purchase the obi cloth asset. I just want to be sure.
1. Can the cloth surface react to user's finger touch? If so, can it create a "hole" in the shape of a finger when pressed on?
2. Also, does the cloth surface allow mixing of colours on runtime? The reference game I showed also has a feature where a colour can be gradually mixed onto the slime.
Cheers.
RE: Using Obi Fluid for Mobile Slime Simulation - arrnav96 - 08-09-2018
Any reply? It's urgent.
RE: Using Obi Fluid for Mobile Slime Simulation - josemendez - 09-09-2018
(08-09-2018, 01:06 PM)arrnav96 Wrote: 1. Can the cloth surface react to user's finger touch? If so, can it create a "hole" in the shape of a finger when pressed on?
1.- This is something you should implement yourself, using the input system provided by Unity. Managing input is not a part of (or even responsibility of) a physics engine.
2.- This also isn't responsibility of the physics engine, but of the rendering pipeline. You should implement this "painting mode" yourself, using the render-related tools Unity puts at your disposal: mesh vertex colors, render targets, shaders, etc.
cheers,
