Is there a way to check that simulation done and all particles is sleeping? - Printable Version
+--- Thread: Is there a way to check that simulation done and all particles is sleeping? (/thread-662.html)
Is there a way to check that simulation done and all particles is sleeping? - mmortall - 22-08-2018
I need somehow to know that all particles are in sleep state. Because I need to stop simulation then, save simulation mesh etc.
For now I use just a timer, but I want to use some smart way to check simulation done. So basically I need to know a percent of perticles are in sleep state and if like 99% in sleep state then considering simulation done.
It there a way to do what I wan currently?
RE: Is there a way to check that simulation done and all particles is sleeping? - josemendez - 22-08-2018
(22-08-2018, 03:48 PM)mmortall Wrote: I need somehow to know that all particles are in sleep state. Because I need to stop simulation then, save simulation mesh etc.
The sleep threshold is expressed in Joules/Kg. So simply check if the kinetic energy of the particles is below the sleep threshold. Pseudocode:
Oni.GetParticleVelocities(solver,velocities,numParticles,startingParticle);
for (int i = 0; i < velocities.Length;++i)
    if (velocities[i].sqrMagnitude * 0.5f <= solver.parameters.sleepThreshold)
     // this one is sleeping.
See the last bit of: http://obi.virtualmethodstudio.com/tutorials/scriptingparticles.html for more info on how to use low level particle getter/setters.
RE: Is there a way to check that simulation done and all particles is sleeping? - mmortall - 22-08-2018
(22-08-2018, 04:03 PM)josemendez Wrote: The sleep threshold is expressed in Joules/Kg. So simply check if the kinetic energy of the particles is below the sleep threshold. Pseudocode:
Thanks a lot for help. This is exactly what I am looking for.
RE: Is there a way to check that simulation done and all particles is sleeping? - mmortall - 07-05-2019
Hello.
After updating to the new Obi version 4.0.2 and there is no more GetParticleVelocities method.
So I am not able to check the simulation done condition.
How can I do it now in a new version? Thanks
RE: Is there a way to check that simulation done and all particles is sleeping? - josemendez - 07-05-2019
(07-05-2019, 06:41 PM)mmortall Wrote: Hello.
See the updated docs:
RE: Is there a way to check that simulation done and all particles is sleeping? - mmortall - 08-05-2019
(07-05-2019, 08:34 PM)josemendez Wrote: Hi,
Thanks. Will try it
