Help Rope position delay from parent - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Help Rope position delay from parent (/thread-600.html) Pages:
1
2
RE: Rope position delay from parent - VirtualCucumber - 16-05-2018 (16-05-2018, 05:17 PM)josemendez Wrote: Yes, you can just have that. I meant that the arguments of your Move() function should be the same ones declared for OnStepBegin, but I see you already did that. It sill falls behind This is what I have: Code: //Solver declaration, assigned through editor RE: Rope position delay from parent - josemendez - 17-05-2018 (16-05-2018, 05:43 PM)VirtualCucumber Wrote: It sill falls behind Just double checked your movement code. It seems that you're moving things around by setting the velocity of a rigidbody, instead of the position of a transform. This velocity is added to the rigidbody during FixedUpdate, at which point the rope has already been simulated, introducing a 1-frame delay. Simply apply the velocity to the transform yourself. You don't even need a rigidbody (you're not using it at all). Do this: Code: transform.position += velocity * Time.fixedDeltaTime; instead of Code: rb.velocity = velocity; RE: Rope position delay from parent - VirtualCucumber - 19-05-2018 (17-05-2018, 09:05 AM)josemendez Wrote: Just double checked your movement code. It seems that you're moving things around by setting the velocity of a rigidbody, instead of the position of a transform. This velocity is added to the rigidbody during FixedUpdate, at which point the rope has already been simulated, introducing a 1-frame delay. Yeah that's why I was going Translate it instead but due to the simplicity of the project, why not simple code as well Anyway, thanks for the support. Asset is already 5 stars for its flexibility (puns) and now with its awesome support. Looking forward to getting cloth |
