Objects joined with ropes - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Objects joined with ropes (/thread-57.html) |
Objects joined with ropes - wifor - 20-07-2017 I have 4 objects placed in a row and joined together with rope, obi rope, using "Pin Constraints". All ropes are exactly the same but only one works correctly. That is, if I throw the two objects that are hooked to the running rope, drag the rest of objects, but if I throw the others the rope will stretch and never move the other objects. How can I do for all objects to be dragged away? RE: Objects joined with ropes - josemendez - 21-07-2017 (20-07-2017, 02:14 PM)wifor Wrote: I have 4 objects placed in a row and joined together with rope, obi rope, using "Pin Constraints". All ropes are exactly the same but only one works correctly. That is, if I throw the two objects that are hooked to the running rope, drag the rest of objects, but if I throw the others the rope will stretch and never move the other objects. How can I do for all objects to be dragged away? Hi wifor, Can you go into more details about your setup? Is it like this?: object---rope---object----rope----object-----rope----object If this is the case (3 separate ropes, and not a single long rope joining all 4 objects), are all ropes using the same solver? (this is extremely important). Otherwise you would be simulating 3 separate systems, and each rope would completely ignore the existence of the other ropes. RE: Objects joined with ropes - wifor - 24-07-2017 Thanks Jose. That is the problem. I have a solver for each rope. |
