Help Problems when using multiple Skinned Cloths - Printable Version
+--- Thread: Help Problems when using multiple Skinned Cloths (/thread-4422.html)
Problems when using multiple Skinned Cloths - Cat3Man - 08-12-2024
I am experiencing the exact same issue as the one in the following post. What has been done about this issue?
https://obi.virtualmethodstudio.com/forum/thread-4391.html
I also noticed one thing. When using multiple Skinned Cloths for one Obi Solver, if I use the same blueprint for all of them, the problem does not occur. So in your sample scene there is no problem. The problem occurs when you use different blueprints.
RE: Problems when using multiple Skinned Cloths - josemendez - 08-12-2024
(08-12-2024, 11:33 AM)Cat3Man Wrote: I am experiencing the exact same issue as the one in the following post. What has been done about this issue?
This has been fixed in Obi 7.0.4, which is yet unreleased. Send an email to support(at)virtualmethodstudio.com linking this post and I’ll send it to you.
Kind regards,
RE: Problems when using multiple Skinned Cloths - Cat3Man - 09-12-2024
(08-12-2024, 03:09 PM)josemendez Wrote: Hi!
Kind regards,
Thank you!. I sent you an email.
