Help Obi Fluid 7 for Apple Vision Pro - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Help Obi Fluid 7 for Apple Vision Pro (/thread-4382.html) |
Obi Fluid 7 for Apple Vision Pro - AguaRadio - 03-10-2024 Hi there, hope you're doing good. I wanted to inquire if Obi Fluid 7 works on Apple Vision Pro with the change from previous screen-space ellipsoid splatting to isosurface mesh extraction. Currently vision OS builds from Unity currently only support Single-Pass Instanced rendering so I'm curious if the team has tested this in house before I proceed further. Thank you so much for your time. RE: Obi Fluid 7 for Apple Vision Pro - josemendez - 03-10-2024 (03-10-2024, 08:10 AM)AguaRadio Wrote: Hi there, hope you're doing good. Hi, Single-pass stereo for URP VR is fully supported. However we haven't tested it in Apple Vision Pro since we don't own that headset (only tested in Oculus Quest 2 and Vive Pro) , so we have no way to know whether it actually works. If you want to give it a try, upgrading to Obi 7 from previous versions is free. If you don't own Obi but decide to purchase and turns out it doesn't work on Apple Vision, I can refund your purchase. kind regards, |
