Bug / Crash Destroying GameObjects immediately is not permitted during physics trigger/contact - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Bug / Crash Destroying GameObjects immediately is not permitted during physics trigger/contact (/thread-4367.html) |
Destroying GameObjects immediately is not permitted during physics trigger/contact - Alexander34 - 17-09-2024 Code: public void AttachRope()Code: public void DecreaseReferenceCount()Code: Destroying GameObjects immediately is not permitted during physics trigger/contact, animation event callbacks, rendering callbacks or OnValidate. You must use Destroy instead.Code: _src.Scripts.PlayerFeatures.Connection.ThreadProxy_s.ThreadProxy:AttachRope () (at Assets/_src/Scripts/PlayerFeatures/Connection/ThreadProxy's/ThreadProxy.cs:124)Code: ObiRope.ropeBlueprint = _blueprint;in AttachRope method Iam use [6.5.2] obiRope RE: Destroying GameObjects immediately is not permitted during physics trigger/contact - josemendez - 17-09-2024 (17-09-2024, 01:14 PM)Alexander34 Wrote: I made a rope hitch like in the Hook example. And now every time I get this error in ObiCollisionWorld when I use the above AttachRope method. Hi, Where are you calling AttachRope() from? Judging from your stack trace, it would seem like you are doing this from OnTriggerStay() which is a trigger callback. You're deleting the rope and creating it anew, this triggers the collision system destruction (the DestroyImmediate call) during a trigger callback, which as the error message itself is telling you isn't allowed: Quote:Destroying GameObjects immediately is not permitted during physics trigger/contact Simplest workaround is to store the condition using a boolean, and attach the rope during Update() or some other callback that's not part of the triggers/collision system. kind regards, RE: Destroying GameObjects immediately is not permitted during physics trigger/contact - Alexander34 - 17-09-2024 (17-09-2024, 01:30 PM)josemendez Wrote: Hi,Generally from many places, I switch the state of the players and at that moment I just disable the rope object(not solver) and then enable and call AttachRope again, so that the new rope takes into account the changed position of the players in space and a new rope of a new length is generated. The death event can be triggered by a collision with a dangerous object or trigger, it switches the player's state to death and does the above with the rope actually everything works fine in general, but it's the regular warning that bothers me, and if I change the method to Destroy() instead of DestroyImmediately(), the burst starts complaining that it loses references to objects while executing jobs. RE: Destroying GameObjects immediately is not permitted during physics trigger/contact - josemendez - 17-09-2024 (17-09-2024, 01:37 PM)Alexander34 Wrote: The death event can be triggered by a collision with a dangerous object or trigger, it switches the player's state to death and does the above with the rope Right, but you can't do this operation on a collision/trigger callback. As explained, the correct way to do this is to store some indication that the rope must be attached, then do the actual AttachRope() call outside of the trigger callback. This is similar to what you'd do for reacting for input on FixedUpdate(): you can't read input on FixedUpdate() since it may not be called every frame and you'd be missing keystrokes, so you read input in Update(), store input indicators (booleans, enums, etc) and then react to it during FixedUpdate(). (17-09-2024, 01:37 PM)Alexander34 Wrote: if I change the method to Destroy() instead of DestroyImmediately(), the burst starts complaining that it loses references to objects while executing jobs. You can't do this, since Destroy() defers destruction until the end of the frame which is too late in this case. We use DestroyImmediate() instead for a reason. RE: Destroying GameObjects immediately is not permitted during physics trigger/contact - Alexander34 - 17-09-2024 (17-09-2024, 01:30 PM)josemendez Wrote: Hi,Yes cashing bool and use it in update was helpful, thank's. But perhaps, we can unload rope more safe? RE: Destroying GameObjects immediately is not permitted during physics trigger/contact - josemendez - 17-09-2024 (17-09-2024, 02:13 PM)Alexander34 Wrote: Yes cashing bool and use it in update was helpful, thank's. You're welcome (17-09-2024, 02:13 PM)Alexander34 Wrote: But perhaps, we can unload rope more safe? Not really. Unloading the last rope in the scene causes the destruction of the collision system, which must be done using DestroyImmediate(). Doing this in response to a collision/trigger is forbidden by Unity. kind regards, |
