Bug / Crash (Obi7) Particle renderer not working - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Bug / Crash (Obi7) Particle renderer not working (/thread-4231.html) |
(Obi7) Particle renderer not working - NekoKOKO - 22-05-2024 Hi team, I'm trying to use the Obi Particle Renderer to visualize the particles using Obi7 in the Benchmark Scene, but nothing shows up there in the scene. I switched back to Obi6 and it's working as expected, so I believe this is a bug of the new plugin. RE: (Obi7) Particle renderer not working - josemendez - 22-05-2024 (22-05-2024, 06:51 PM)NekoKOKO Wrote: Hi team, Hi, I'm unable to reproduce this. Which render pipeline are you using? RE: (Obi7) Particle renderer not working - NekoKOKO - 22-05-2024 (22-05-2024, 07:32 PM)josemendez Wrote: Hi,I'm using Built-in Render Pipeline (the default one). RE: (Obi7) Particle renderer not working - josemendez - 24-05-2024 (22-05-2024, 09:08 PM)NekoKOKO Wrote: I'm using Built-in Render Pipeline (the default one). Still unable to reproduce this, here's the "Benchmark" scene with a ObiParticleRenderer added to one of the flags. Using Compute or Burst backends makes no difference: ![]() Make sure you've installed ShaderGraph in your project, as stated in the manual. Otherwise none of the included shaders will work: http://obi.virtualmethodstudio.com/manual/7.0/setup.html Try selecting /Obi/Resources/ObiMaterials/Common/ParticleShader.shadergraph, see if there's any errors in the inspector: ![]() If these do not solve the issue, would it be possible for you to share a project that showcases this problem by sending it to support(at)virtualmethodstudio.com? thanks! |
