Help Fluid flickering if rendered together - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Help Fluid flickering if rendered together (/thread-3555.html) |
Fluid flickering if rendered together - schromercy - 15-08-2022 Hi Obi team, I make a test scene where there are 2 fluid emitters, strangely one of the fluid emitter are flickering Sample video can be seen here: flickering video When i tried to disable the other emitter, leaving only 1 emitters active the flickering issue are gone Sample video can be seen here: flickering gone after disable other emitter video Here are the sample project i used to generate the issue, hope it helps: sample project link How should we fix the flickering issue? Thanks in advance! |
