Obi fluid DllNotFound - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Obi fluid DllNotFound (/thread-3503.html) |
Obi fluid DllNotFound - Harutyun - 24-06-2022 Hi, I've imported both Obi fluid and Obi softbody and I got this error in my console DllNotFoundException: libOni assembly:<unknown assembly> type:<unknown type> member null)Obi.OniBackend.CreateSolver (Obi.ObiSolver solver, System.Int32 capacity) (at Assets/Obi/Scripts/Common/Backends/Oni/OniBackend.cs:17) Obi.ObiSolver.Initialize () (at Assets/Obi/Scripts/Common/Solver/ObiSolver.cs:851) Obi.ObiSolver.AddActor (Obi.ObiActor actor) (at Assets/Obi/Scripts/Common/Solver/ObiSolver.cs:1112) Obi.ObiActor.AddToSolver () (at Assets/Obi/Scripts/Common/Actors/ObiActor.cs:348) Obi.ObiActor.OnEnable () (at Assets/Obi/Scripts/Common/Actors/ObiActor.cs:323) RE: Obi fluid DllNotFound - josemendez - 25-06-2022 (24-06-2022, 10:14 PM)Harutyun Wrote: Hi, I've imported both Obi fluid and Obi softbody and I got this error in my console Hi! Just restart Unity. See our FAQ for details: http://obi.virtualmethodstudio.com/faq.html Also make sure to follow the setup instructions in the manual: http://obi.virtualmethodstudio.com/manual/6.3/setup.html RE: Obi fluid DllNotFound - Harutyun - 26-06-2022 (25-06-2022, 07:31 AM)josemendez Wrote: Hi!Restarting does not help. Also, I'm using URP, and most importantly using Apple Silicone Editor on M1 machine, may that cause these problems? RE: Obi fluid DllNotFound - josemendez - 26-06-2022 (26-06-2022, 09:12 AM)Harutyun Wrote: Restarting does not help. Hi! The fallback library used in case you haven’t installed the required packages does not support the M1 architecture. Make sure to install the required packages for the Burst backend, as explained in the setup instructions: http://obi.virtualmethodstudio.com/manual/6.3/backends.html RE: Obi fluid DllNotFound - Harutyun - 26-06-2022 Ok I've installed all required packages, but now it gives me errors during runtime. DllNotFoundException: libOni assembly:<unknown assembly> type:<unknown type> member null)Obi.ObiProfiler.DisableProfiler () (at Assets/Obi/Scripts/Common/Utils/ObiProfiler.cs:84) Obi.ObiFixedUpdater.Update () (at Assets/Obi/Scripts/Common/Updaters/ObiFixedUpdater.cs:65) RE: Obi fluid DllNotFound - josemendez - 26-06-2022 (26-06-2022, 10:34 AM)Harutyun Wrote: Ok I've installed all required packages, but now it gives me errors during runtime. The ObiProfiler component only works with the Oni(fallback) backend, as explained in the link I shared in the last post. If you’re using Burst you should just use Unity’s built in profiler sincr it has native integration. Simply remove the ObiProfiler component from your scene, the error will go away. Let me know if you need further help, RE: Obi fluid DllNotFound - Harutyun - 26-06-2022 Ok thanks, it worked. |
