Bug / Crash sample scenes fail to build - Printable Version +- Obi Official Forum (http://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (http://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (http://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Bug / Crash sample scenes fail to build (/thread-3495.html) |
sample scenes fail to build - jpc2tao - 21-06-2022 I opened an empty 3D project and imported packages Burst, Collections, Mathematics then Obi Fluid 6.4 as suggested. The sample scenes run without issue in Game mode, but fails to build. I get the following Error: Shader error in 'Obi/URP/Particles': Couldn't open include file 'Packages/com.unity.render-pipelines.universal/ShaderLibrary/Core.hlsl'. at Assets/Obi/Resources/ObiMaterials/URP/ObiLightingURP.cginc(3) I included the whole log in the attachment. The specific scene I am trying to build is MultiPhaseFluidBuoyancy, although all other scenes are having similar build problems. Unity Version 2021.3.7f1 Obi Version 6.4 Burst 1.6.6 Collections 1.3.1 Mathematics 1.2.6 Jobs 0.51.0-preview.32 RE: sample scenes fail to build - josemendez - 21-06-2022 (21-06-2022, 01:23 PM)jpc2tao Wrote: I opened an empty 3D project and imported packages Burst, Collections, Mathematics then Obi Fluid 6.4 as suggested. Hi, if you're not using URP, you need to remove the entire Obi/Resources/ObiMaterials/URP folder as stated in the setup instructions: http://obi.virtualmethodstudio.com/manual/6.3/setup.html Quote:If you're not using SRPs but the built-in pipeline, it's safe to delete the /Obi/Resources/ObiMaterials/URP folder. Otherwise Unity will raise an error at build time, stating that it cannot find the URP pipeline installed. kind regards, RE: sample scenes fail to build - jpc2tao - 21-06-2022 Thanks, that solved the problem. |
