Help How to prepare rope like on the screen - Printable Version
+--- Thread: Help How to prepare rope like on the screen (/thread-3415.html)
How to prepare rope like on the screen - Alexander - 22-04-2022
Hi all, I need help. Making a game like Tangle Master 3d. How can I prepare such levels where the ropes are twisted together several times?
https://prnt.sc/P_U7w2KUFLz8
RE: How to prepare rope like on the screen - josemendez - 22-04-2022
(22-04-2022, 12:09 PM)Alexander Wrote: Hi all, I need help. Making a game like Tangle Master 3d. How can I prepare such levels where the ropes are twisted together several times?
Hi Alexander,
This question is extremely broad. What do you mean by "preparing" the levels? loading them from a file? manually setting up scenes in the editor? procedurally creating the ropes?
RE: How to prepare rope like on the screen - Alexander - 22-04-2022
(22-04-2022, 12:25 PM)josemendez Wrote: Hi Alexander,
Hi josemendez. Sorry for that. I need any solution that can help me to build this level. Manually setting up scenes in the editor or saving in prefab will be preferable solution
(22-04-2022, 12:39 PM)Alexander Wrote: Hi josemendez. Sorry for that. I need any solution that can help me to build this level. Manually setting up scenes in the editor or saving in prefab will be preferable solution
If manually setting this up in the editor is ok, then you can just use Obi's path editor to define the starting path of the ropes (twisted around each other, or any other initial shape) See: http://obi.virtualmethodstudio.com/manual/6.3/ropesetup.html
(22-04-2022, 12:46 PM)josemendez Wrote: If manually setting this up in the editor is ok, then you can just use Obi's path editor to define the starting path of the ropes (twisted around each other, or any other initial shape) See: http://obi.virtualmethodstudio.com/manual/6.3/ropesetup.html
Thanks josemendez, I'll try
