Obi softbody 6.4 not work on Ubuntu - Printable Version
+--- Thread: Obi softbody 6.4 not work on Ubuntu (/thread-3370.html)
Obi softbody 6.4 not work on Ubuntu - SimonFu - 21-03-2022
Hi there, my platform is Ubuntu 16.04 with Unity Editor 2020.3.15f2.
I am trying to use obi softbody 6.4. When I load this package into Unity Editor, everything is OK, only some warnings in console.
But if I want to run a demo, e.g. BallPool, when I press the `run` button on the top, Unity Editor crashes with a window named `Unity has stopped working`. Huh
I've also tried other demos, no one can be successfully run.
I haven't test it on other versions of Unity Editor on Linux platform, I wonder if others have the same problem with me. Idea
Hope to hear your reply soon! Corazón
RE: Obi softbody 6.4 not work on Ubuntu - josemendez - 21-03-2022
(21-03-2022, 05:37 AM)SimonFu Wrote: Hi there, my platform is Ubuntu 16.04 with Unity Editor 2020.3.15f2.
Hi Simon!
Did you follow the setup steps in the manual? Specifically, did you install the required dependencies for the Burst backend?:
http://obi.virtualmethodstudio.com/manual/6.3/setup.html
http://obi.virtualmethodstudio.com/manual/6.3/backends.html
RE: Obi softbody 6.4 not work on Ubuntu - SimonFu - 23-03-2022
(21-03-2022, 08:43 AM)josemendez Wrote: Hi Simon!
Thanks! That works!
