Custom Gravity - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: General (https://obi.virtualmethodstudio.com/forum/forum-5.html) +--- Thread: Custom Gravity (/thread-3312.html) |
Custom Gravity - Sphax - 10-02-2022 I would like to know if anything is documented regarding the implementation of custom gravity for Obi Rope and Obi Soft Body. Is there a way to apply a gravity force to each particle of a rope or a soft body? Or at least a way to apply a force to the whole object? It looks like I can't find anything regarding that on the documentation. RE: Custom Gravity - josemendez - 10-02-2022 (10-02-2022, 10:52 AM)Sphax Wrote: I would like to know if anything is documented regarding the implementation of custom gravity for Obi Rope and Obi Soft Body. Hi, You can apply any external forces to each individual particle by writing into solver.externalForces, or solver.velocities if you want custom accelerations instead. The particles API is really powerful, you can get or set any particle property at any time by simply accessing an array. See: http://obi.virtualmethodstudio.com/manual/6.3/scriptingparticles.html For an example of applying custom gravity to all particles within a trigger collider, see: http://obi.virtualmethodstudio.com/manual/6.3/scriptingcollisions.html You can also apply forces to the whole object, by using actor.AddForce(). See the ObiActor class API docs for details: http://obi.virtualmethodstudio.com/api.html |
