Multiple obi solvers - Printable Version
+--- Thread: Multiple obi solvers (/thread-3280.html)
Pages: 1 2
RE: Multiple obi solvers - lufydad - 24-01-2022
(21-01-2022, 06:12 PM)josemendez Wrote: Depends on the mesh colliders, how many triangles each?
There are 49 mesh colliders, with an average of 103 triangles for one collider.
(21-01-2022, 06:12 PM)josemendez Wrote: Bounding Volume Hierarchies. It's the acceleration data structure used to perform collision queries against triangle meshes.
Since testing each particle against each individual triangle in each collider is too much work, a BVH for each mesh is generated. This allows to quickly prune triangles that are not close to a given particle, and allows to test each particle agains just a few (2-3) triangles. Basically, it makes collision detection fast enough to run in realtime.
The thing is that generating the BVH takes some time. In Obi a better alternative to MeshColliders are distance fields, since A) they're built at edit time and stored in disk, so no runtime overhead B) they're faster and more robust than MeshColliders.
Thanks for this small lesson, I have never studied how collision detection works.
However, I test my asset with or without the mesh colliders, and the performances seems to be approximately the same. This is why it doesn't seems to me that colliders are the cause of these problems in performances.
RE: Multiple obi solvers - josemendez - 24-01-2022
(24-01-2022, 02:10 PM)lufydad Wrote: There are 49 mesh colliders, with an average of 103 triangles for one collider.
In that case we're back to square one: I have no idea what could be causing this.
I know your project is big, but would it be possible for you to strip your scene of all non-essential content, to try and get the simplest setup that reproduces this problem and share it with me? Otherwise all I can do is guesswork.
(24-01-2022, 03:05 PM)josemendez Wrote: Hi there,
Unfortunately, I'm under a non-disclosure agreement, therefore I even can't share you an empty scene with only the asset...
However, I thank you for all your help !!!
If I find something more precise that affect performances, I'll share it to you.
Once again thank you !
RE: Multiple obi solvers - josemendez - 25-01-2022
(24-01-2022, 04:10 PM)lufydad Wrote: Unfortunately, I'm under a non-disclosure agreement, therefore I even can't share you an empty scene with only the asset...
What I meant was stripping the project of any sensible content until there's only Obi stuff in there that reproduces the problem. An empty scene with only Obi in it cannot possibly be under NDA right? Sonrisa
This is usually the best way to get help or report bugs: by creating a minimal reproducible example.
(24-01-2022, 04:10 PM)lufydad Wrote: However, I thank you for all your help !!!
You're welcome! Let me know if I can be of any help.
