How to give a tension to rope... - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: How to give a tension to rope... (/thread-3140.html) |
How to give a tension to rope... - sangku2000 - 20-10-2021 Hi! I wanna give a rope tense. No longer give a length to rope but when i move a rope's X transform, it getting more longger..... What can i do...? this is now. no tension, and draw is my expectaition. RE: How to give a tension to rope... - josemendez - 20-10-2021 Tension is defined as a force that increases strain. Strain is the ratio between the rope's rest length and its current length: Code: float strain = rope.restLength / rope.CalculateLength(); So if you want to increase strain, all you need to do is reduce the rope's rest length so that it is a percentage of the length between the points it is attached to. You can use a cursor to do that, like this: Code: cursor.ChangeLength(Vector3.Distance(attachmentA, attachmentB) * 0.6f); //rope is 40% shorter than the distance between its endpoints. See: http://obi.virtualmethodstudio.com/manual/6.2/ropecursor.html RE: How to give a tension to rope... - sangku2000 - 21-10-2021 It not changing a component but a code? And than, what script? I've searched all scripts using a keyword "cursor.ChangeLength" but, i only found ObiRopeCursor.cs .... is it correct to change this cs file?? RE: How to give a tension to rope... - josemendez - 21-10-2021 (21-10-2021, 02:36 AM)sangku2000 Wrote: It not changing a component but a code? Yes, you need to write some code for this to work. (21-10-2021, 02:36 AM)sangku2000 Wrote: And than, what script? Your own script, you need to write a script that calls cursor.ChangeLength(yourNewLength), where "cursor" is a variable of type ObiCursor. (21-10-2021, 02:36 AM)sangku2000 Wrote: I've searched all scripts using a keyword "cursor.ChangeLength" but, i only found ObiRopeCursor.cs ....is it correct to change this cs file?? Im a bit confused by this question...you don't have to change ObiRopeCursor.cs or any other Obi script, if you do you can break the asset. ChangeLength() is a public method exposed by ObiRopeCursor. You simply add a ObiRopeCursor component to your rope, and then call its ChangeLength() method in your own script. Take a look at the manual for an in-depth explanation and some sample code: http://obi.virtualmethodstudio.com/manual/6.2/ropecursor.html Note C# scripting skills are an absolute requirement to be able to use Obi, if you're unfamiliar with scripting/programming you'll find it very hard to use. See our FAQ: http://obi.virtualmethodstudio.com/faq.html Quote:Is scripting / coding required to use Obi? RE: How to give a tension to rope... - sangku2000 - 22-10-2021 Thanks for your advise! It perfectly work! ↓ this is my code! public class RopeStrain : MonoBehaviour { ObiRopeCursor cursor; ObiRope rope; public Transform attachmentStart; public Transform attachmentEnd; public float distanceRate = 0.45f; // Start is called before the first frame update void Start() { rope = GetComponent<ObiRope>(); cursor = GetComponent<ObiRopeCursor>(); } // Update is called once per frame void LateUpdate() { AdjustStrain(); } private void AdjustStrain() { if (attachmentStart == null || attachmentEnd == null) { #if UNITY_EDITOR Debug.Log("transform null...!!!"); #endif return; } cursor.ChangeLength(Vector3.Distance(attachmentStart.transform.position, attachmentEnd.transform.position) * distanceRate * Time.deltaTime); // length is adjusted by rate and time. } But.... I think self collider is seem to be not working... I think i need to recalculate the element.. is right? RE: How to give a tension to rope... - josemendez - 22-10-2021 (22-10-2021, 04:07 AM)sangku2000 Wrote: cursor.ChangeLength(Vector3.Distance(attachmentStart.transform.position, attachmentEnd.transform.position) * distanceRate * Time.deltaTime); Do not multiply by Time.deltaTime, it does not make any sense in this context. You're not changing the length over time, you're just setting it to a specific value. Multiplying by Time.deltaTime (which is a very, very small value, like 0.001) will set the length of your rope to be pretty much zero. This will result in a rope made of only two particles: one at each end. So no collisions will take place since there are no particles to collide with. (22-10-2021, 04:07 AM)sangku2000 Wrote: I think i need to recalculate the element.. is right? No need to ![]() RE: How to give a tension to rope... - sangku2000 - 22-10-2021 cursor.ChangeLength(Vector3.Distance(attachmentStart.transform.position, attachmentEnd.transform.position) * distanceRate); // rope adjust by rate. ↑↑↑↑↑ This is new code...! (distanceRate is almost 0.1f) But collider is not works now. Because of no particle impacted. (you've said) I wanna make when ropes contact, they become a tangle. (now ropes doesn't impact each other) In this situation, I need to recalculate rope's particles or make own particles?? I think i torture you.... Sorry... very very sorry.... RE: How to give a tension to rope... - josemendez - 22-10-2021 (22-10-2021, 09:19 AM)sangku2000 Wrote: cursor.ChangeLength(Vector3.Distance(attachmentStart.transform.position, attachmentEnd.transform.position) * distanceRate); // rope adjust by rate. Add a ObiParticleRenderer component to your rope, make sure there's particles all along the rope. See: http://obi.virtualmethodstudio.com/manual/6.2/particlerendering.html Assuming the rope does contain enough particles and there's no large gaps in between them, there's other issues that can prevent accurate collision detection: - Make sure particle collision constraints are enabled in the solver: http://obi.virtualmethodstudio.com/manual/6.2/obisolver.html - Make sure collision filters are properly set up. By default, ropes collide with everything, so unless you've changed this or you've reused a blueprint that had incorrect filter settings, it should work fine. For info on collision filters, see:http://obi.virtualmethodstudio.com/manual/6.2/collisions.html - If your ropes are very tense, then gaps can appear in between particles, allowing ropes to pass trough each other. Using surface collisions can improve this. See: http://obi.virtualmethodstudio.com/manual/6.2/surfacecollisions.html You mention your distanceRate variable is 0.1, that will make the rope 10% of the distance between its ends and will likely open huge gaps in between particles. I don't think you need such large tension, any real-world rope or chain would snap under such strain. distanceRate is meant to be set to 0.8-0.99, or some value close to 1. (22-10-2021, 09:19 AM)sangku2000 Wrote: In this situation, I need to recalculate rope's particles or make own particles?? No need to. Ropes will readily collide with each other, as long as they're correctly setup. (22-10-2021, 09:19 AM)sangku2000 Wrote: Sorry... very very sorry.... No worries! answering questions is what I'm here for ![]() |
