Suggestion / Idea ObiUpdater needlessly allocates every frame - Printable Version
+--- Forum: General (https://obi.virtualmethodstudio.com/forum/forum-5.html)
+--- Thread: Suggestion / Idea ObiUpdater needlessly allocates every frame (/thread-3072.html)
ObiUpdater needlessly allocates every frame - timconkling - 19-08-2021
I've been having performance issues with Obi Cloth, and have been spending lots of time in the profiler to get a handle on how to improve things.
I've noticed that Obi allocates quite a lot of memory each frame - in my scene with 6 clothed characters, `ObiLateFixedUpdater` is allocating ~2.5 kb each frame. At least some of this is very easily eliminated.
`ObiUpdater.BeginStep` and `ObiUpdater.Substep` both allocate a new temporary List each time they're called. This list can be moved into a member variable to avoid the repeated allocation:
private List<IObiJobHandle> m_JobHandles = new List<IObiJobHandle>();
protected void Substep(float stepDeltaTime, float substepDeltaTime, int index)
    using (m_SubstepPerfMarker.Auto())
        // Kick off all solver jobs:
        foreach (ObiSolver solver in solvers)
            if (solver != null)
                this.m_JobHandles.Add(solver.Substep(stepDeltaTime, substepDeltaTime, index));
        // wait for all solver jobs to complete:
        foreach (IObiJobHandle handle in this.m_JobHandles)
            if (handle != null)
                handle.Complete();
        this.m_JobHandles.Clear();
`ObiSolver.Update` also does some unnecessary allocation, because it calls `Mathf.Max(params float[])`, which allocates a temporary params array. (It also accesses `transform.lossyScale` - which I think involves a roundtrip out of managed code and into the engine - three times). I've made this minor tweak:
void Update()
    var lossyScale = transform.lossyScale;
    m_MaxScale = Mathf.Max(Mathf.Max(lossyScale.x, lossyScale.y), lossyScale.z);
These changes bring my allocations down to ~1.5kb per frame, which is a good start - but far from perfect!
I really like Obi, and I'm a bit surprised to see so much `GC.alloc` action every frame. I'd love to be able to do cloth simulation without any allocations... might there be a performance pass done in the future?
Cheers!
RE: ObiUpdater needlessly allocates every frame - josemendez - 19-08-2021
(19-08-2021, 12:07 AM)timconkling Wrote: I've been having performance issues with Obi Cloth, and have been spending lots of time in the profiler to get a handle on how to improve things.
            if (solver != null)
            if (handle != null)
                handle.Complete();
void Update()
Cheers!
Thanks a lot for the input! One of these (the updater list<> as a class member had been already addressed in the development branch, but I wasn't aware of the other one (Mathf.Max allocating a temporary array for any more than 2 arguments Indeciso ). Both improvements will be included.
Regularly I profile Obi and grab low-hanging fruit, however not all have been picked yet. Expect less garbage generation in upcoming releases.
RE: ObiUpdater needlessly allocates every frame - timconkling - 19-08-2021
(19-08-2021, 01:00 PM)josemendez Wrote: Hi there!
That's great to hear, thanks Jose!
RE: ObiUpdater needlessly allocates every frame - pdinklag - 28-12-2021
The allocations required for the job handles returned by BeginStep and Substep are kinda "annoying". They return a new class instance every time (BurstJobHandle in the case of the Burst backend), and I see this is conceptually necessary because there are two backends and the shared interface IObiJobHandle is used. However, both those classes are so simple that I don't think this deserves an allocation each and every frame.
For my project, I added a pool for the burst job handles now, which I release before the Clear that @timconkling added. This gets rid of regular allocations and does not need much refactoring (I added a Release method to the IObiJobHandle interface). Something like this should definitely be adopted in Obi.
With this change and the others I proposed (http://obi.virtualmethodstudio.com/forum/thread-3251.html and http://obi.virtualmethodstudio.com/forum/thread-3250.html), I seem to be down to zero per-frame GC allocations for Obi.
RE: ObiUpdater needlessly allocates every frame - josemendez - 10-01-2022
(28-12-2021, 11:05 AM)pdinklag Wrote: The allocations required for the job handles returned by BeginStep and Substep are kinda "annoying". They return a new class instance every time (BurstJobHandle in the case of the Burst backend), and I see this is conceptually necessary because there are two backends and the shared interface IObiJobHandle is used. However, both those classes are so simple that I don't think this deserves an allocation each and every frame.
Hi pdinklag,
Thanks a lot for your reports/contributions! This one and the allocation in Decimate() will certainly make their way onto Obi's codebase.
Keep an eye for them in Obi 6.3.1.
