Obiparticleattachment - mayaeraky - 02-06-2021
Hi there, I am trying to grab my obi cloth in VR using steamVR. I tried attaching the cloth to the hand after any contact between the hand and any particle of the cloth using contact event handler and obi particle attachment but there is a huge gap between the hand and the particles attached. They’re attached correctly movement wise but they are not overlapping which makes it look weird.
Thank you
RE: Obiparticleattachment - josemendez - 03-06-2021
(02-06-2021, 07:26 PM)mayaeraky Wrote: Hi there, I am trying to grab my obi cloth in VR using steamVR. I tried attaching the cloth to the hand after any contact between the hand and any particle of the cloth using contact event handler and obi particle attachment but there is a huge gap between the hand and the particles attached. They’re attached correctly movement wise but they are not overlapping which makes it look weird.
Thank you
Without any details and no code it's hard to tell what could be wrong. My guesses are either:
1.- There's a collider conflicting with the attachment, preventing the particle from moving to its attached position.
2.- The attachment offset is wrong (the position of the particle at the time of attaching doesn't match the intended attachment pos).
Also note that ObiContactGrabber does pretty much this: exposes a Grab() method that attaches particles to the collider in contact with them.
RE: Obiparticleattachment - mayaeraky - 03-06-2021
(03-06-2021, 09:13 AM)josemendez Wrote: Hi there,
Also note that ObiContactGrabber does pretty much this: exposes a Grab() method that attaches particles to the collider in contact with them. Hi again,
I checked for both options and I don't think it's either of them but anyways I'm going to attach the code for you to check it if possible. The following script is added to the Obisolver.
Code: using UnityEngine;
using System.Collections;
using Obi;
public class CollisionEventHandler : MonoBehaviour
ObiSolver solver;
public int contactCount;
//public GameObject obj;
Obi.ObiSolver.ObiCollisionEventArgs frame;
void Awake()
solver = GetComponent<Obi.ObiSolver>();
//GetComponentInChildren<ObiCloth>().blueprint.ClearParticleGroups();
void OnEnable()
void OnDisable()
void Solver_OnCollision(object sender, Obi.ObiSolver.ObiCollisionEventArgs e)
// just iterate over all contacts in the current frame:
if (contact.distance < 0.01)
if (col != null && (col.gameObject.name == "LeftHand" || col.gameObject.name == "RightHand"))
Debug.Log("heree");
// get particles involved
int simplexStart = solver.simplexCounts.GetSimplexStartAndSize(contact.bodyA, out int simplexSize);
ObiParticleAttachment attachment = GetComponentInChildren<ObiParticleAttachment>();
ObiParticleGroup temp = attachment.particleGroup;
//List<int> collisionIndices = new List<int>();
//Debug.Log("Particle Groups: " + GetComponentInChildren<ObiCloth>().blueprint.groups.Count);
for (int i = 0; i < simplexSize; ++i)
int particleIndex = solver.simplices[simplexStart + i];
if (temp.particleIndices.Count < 3)
temp.particleIndices.Add(particleIndex);
//Debug.Log("Temp Count: " + temp.Count);
attachment.particleGroup = temp;
attachment.enabled = true;
frame = e;
void OnDrawGizmos()
if (solver == null || frame == null || frame.contacts == null) return;
Gizmos.matrix = solver.transform.localToWorldMatrix;
contactCount = frame.contacts.Count;
for (int i = 0; i < frame.contacts.Count; ++i)
var contact = frame.contacts.Data[i];
//if (contact.distance > 0.001f) continue;
Gizmos.color = (contact.distance <= 0) ? Color.red : Color.green;
//Gizmos.color = new Color(((i * 100) % 255) / 255.0f, ((i * 50) % 255) / 255.0f, ((i * 20) % 255) / 255.0f);
Vector3 point = frame.contacts.Data[i].pointB;
Gizmos.DrawSphere(point, 0.01f);
Gizmos.DrawRay(point, contact.normal * contact.distance);
Gizmos.color = Color.cyan;
Gizmos.DrawRay(point, contact.tangent * contact.tangentImpulse + contact.bitangent * contact.bitangentImpulse);
Also, about ObiContactGrabber I tried using it but for some reason it wouldn't grab the cloth when the method grab is called. I will add the code of it too in case you can check it and tell me how to make it work. The script is added to the hand along with ObicontactGrabber component, Obi collider, and sphere collider.
using UnityEngine;
using Obi;
using Valve.VR;
//[RequireComponent(typeof(ObiSolver))]
public class handgrabbing : MonoBehaviour
public SteamVR_Input_Sources source = SteamVR_Input_Sources.LeftHand;
bool handclosed;
ObiSolver held;
ObiContactGrabber contact;
void Start()
// held = GetComponent<Obi.ObiSolver>();
contact = GetComponent<ObiContactGrabber>();
void FixedUpdate()
if (SteamVR_Actions.default_GrabPinch.GetState(source)) {
handclosed = true;
Debug.Log("handclosed");
} else {
handclosed = false;
Debug.Log("NOT handclosed");
if (!handclosed) {
contact.Release();
} else {
contact.Grab();
if you need to ask me about any details, do not hesitate.
Thank you
RE: Obiparticleattachment - mayaeraky - 07-06-2021
If you know why it's not working please let me know ASAP as I'm on a deadline.
Thank you
RE: Obiparticleattachment - josemendez - 07-06-2021
A slight variation of your code works fine for me. I simply replaced the SteamVr stuff with Input.GetKey(). Just make sure the collider in the hand is in contact with a particle:
Code: //[RequireComponent(typeof(ObiSolver))]
bool handclosed;
ObiSolver held;
void Start()
void FixedUpdate()
if (Input.GetKey(KeyCode.Space)) {
handclosed = true;
} else {
handclosed = false;
if (!handclosed) {
contact.Release();
} else {
contact.Grab();
(07-06-2021, 10:45 AM)josemendez Wrote: A slight variation of your code works fine for me. I simply replaced the SteamVr stuff with Input.GetKey(). Just make sure the collider in the hand is in contact with a particle:
bool handclosed;
ObiSolver held;
void Start()
void FixedUpdate()
handclosed = true;
} else {
handclosed = false;
if (!handclosed) {
contact.Release();
} else {
contact.Grab();
Thank you so much will try it today.
