Help mix two fluids - Printable Version
+--- Thread: Help mix two fluids (/thread-2935.html)
mix two fluids - GinHuang - 15-05-2021
When I tried to mix two fluids,The particles will explode and fly around. Is it currently impossible to mix liquids in this way?
[attachment=1021]
RE: mix two fluids - josemendez - 15-05-2021
(15-05-2021, 06:11 AM)GinHuang Wrote: When I tried to mix two fluids,The particles will explode and fly around. Is it currently impossible to mix liquids in this way?
There's 3 fluid sample scenes included with Obi that involve mixing in some way: MultiphaseFluidBuoyancy, FluidRaileighTaylor, and FluidMixing.
There should be no problem mixing different fluids, unless they have a huge density ratio. Could you share more details about your setup?
RE: mix two fluids - GinHuang - 15-05-2021
(15-05-2021, 12:05 PM)josemendez Wrote: Hi,
hello!I'm sorry about my English!
I can reproduce this phenomenon.  In the sample scene named “FaucetAndBucket”,you can copy a faucet(and it's emitter) and put it next to the first faucet
,and switch on the particle render. Just play the game, you will see one of the emitter-particle explode at the beginning time.
And this explode emitter-particle was not be Completely render with the obi fluid renderer.
if you set the intact emitter speed zero,and play the game ,you will see the damaged emitter emits particles was highly compressed
[attachment=1022]
(15-05-2021, 02:54 PM)GinHuang Wrote: hello!I'm sorry about my English!
I’d assume you’re using the Oni backend, right? This is a known bug that has been fixed for the next update. It only happens if you’ve not installed the required dependencies for the default backend, so the engine will fallback to the native lib.
Make sure you’ve installed the required Burst dependencies, as listed in the http://obi.virtualmethodstudio.com/tutorials/backends.html
Burst 1.3.3 or newer
Collections 0.8.0-preview 5 or newer
Mathematics 1.0.1 or newer
Jobs 0.2.9-preview.15 or newer
Kind regards,
(15-05-2021, 03:05 PM)josemendez Wrote: Hi,
Kind regards,
oh!yes! I am using the Oni backend! Thank you! I  will see the Burst install (I thought it was a bit of a hassle before. haha!) Thank you very much!
