Possible memory leak? - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Possible memory leak? (/thread-2827.html) Pages:
1
2
RE: Possible memory leak? - josemendez - 07-03-2022 (07-03-2022, 01:13 PM)litefeel Wrote: Hi. did you find and fixed it. Hi there, So far I've been unable to reproduce any memory leaks, if you have a repro project please send it to support(at)virtualmethodstudio.com so that i can take a look. RE: Possible memory leak? - SpiralCircus - 14-03-2022 I have run into the same issue I believe. It is affecting my ability to pass console soak-in tests for certification. I have sent a repro project to the support email address. If Obi solver is active with burst backend, native array memory gradually increases and never seems to decrease. I am using rope not cloth, but I thought it better to keep this post alive rather than create a new one. [Edit: I have noticed also that there is no code compiled in the burst inspector for NativeArrayDisposeJob. I don't know if thisd is relevant but seems like it might be (see image)] RE: Possible memory leak? - josemendez - 14-03-2022 Hi Dominic, Thanks for the repro project! Will take a look at it asap and get back to you. RE: Possible memory leak? - SpiralCircus - 14-03-2022 (14-03-2022, 02:38 PM)josemendez Wrote: Hi Dominic, Thanks for the quick response as always Jose. RE: Possible memory leak? - josemendez - 17-03-2022 Hi, Leaving this here for future readers: As of Obi 6.4, yes there was a memory leak affecting particle collision constraints in the Burst backend. Thanks to SpiralCircus' report I was able to identify and fix it. All you need to fix it in your project is to replace NativeMultilevelGrid.cs with the one attached. |
