Help [obi rod]To change the size of the spring? - Printable Version
+--- Thread: Help [obi rod]To change the size of the spring? (/thread-2762.html)
[obi rod]To change the size of the spring? - nyame - 24-02-2021
Hello! Thank you for your wonderful assets.
How can I resize the rod springs in the obi rope?
Thank you.
RE: [obi rod]To change the size of the spring? - josemendez - 24-02-2021
(24-02-2021, 04:23 AM)nyame Wrote: Hello! Thank you for your wonderful assets.
Thank you.
Currently this isn't possible. Rods use stretch/shear constraints instead of distance constraints (springs), and they don't expose their rest length. In general, rods can't be resized like ropes can. We will consider adding this functionality in future updates.
thanks!
RE: [obi rod]To change the size of the spring? - nyame - 24-02-2021
(24-02-2021, 08:54 AM)josemendez Wrote: こんにちは、
現在これは不可能です。ロッドは、距離拘束(ばね)の代わりにストレッチ/せん断拘束を使用し、静止長を公開しません。一般的に、ロッドはロープのようにサイズを変更することはできません。今後のアップデートでこの機能を追加することを検討します。
ありがとう!
Thank you for your reply! I gave it a 5 star rating in the unity asset store. I'm not good at English, so I'm sorry for the short sentence.
(24-02-2021, 10:16 AM)nyame Wrote: Thank you for your reply! I gave it a 5 star rating in the unity asset store. I'm not good at English, so I'm sorry for the short sentence.
No worries! English isn't my native language either, so we're both doing our best Sonrisa. Thank you!
