Help Irregular Rigidbody reactions - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Help Irregular Rigidbody reactions (/thread-2627.html) |
Irregular Rigidbody reactions - SilverStanley - 11-12-2020 Hi, I have no idea what is going on here, Rope has a Dynamic Obi Particle attachment, attached to a cube(Load) with obi collider and obi rigidbody, the Obi Fixed Update has 3 substeps. The solver is a copy of the Crane solver. The physics material of the obi colliders is all High Friction. When I run the game, the load rigidbody keeps jumping all over the place. GIF of the problem Please help me with this. Thanks in advance RE: Irregular Rigidbody reactions - josemendez - 11-12-2020 (11-12-2020, 02:06 PM)SilverStanley Wrote: Hi, Hi there! 1.- Since you're using both substepping and rigidbody interaction, make sure you've enabled the "substep Unity physics" checkbox in the updater, as per the manual: http://obi.virtualmethodstudio.com/tutorials/updaters.html Quote:Substep Unity physics If you don't, Unity and Obi will update out of sync with each other and cause all sorts of instabilities since you're substepping particle physics but not rigidbody physics. 2.- Make sure you haven't attached the rope inside or very close to the collider, if the rope is set to collide with the rope as well. In this case you need to deactivate collisions between the rope and the collider, as explained here: http://obi.virtualmethodstudio.com/tutorials/pinconstraints.html Easiest thing to do is set the collider's phase to 1: the same as the rope particle's by default. Attaching a rope inside a collider with which it has to collide results in an unsolvable situation: the rope can't be simultaneously inside and outside the collider. This manifests as jittering, as the engine tries to solve a situation that can't possibly be solved. RE: Irregular Rigidbody reactions - SilverStanley - 11-12-2020 (11-12-2020, 02:09 PM)josemendez Wrote: Hi there! Thanks for the response Jose. It is working like a charm now. RE: Irregular Rigidbody reactions - josemendez - 11-12-2020 You're welcome! let me know if I can be of further help. |
