Errors with version 5.6 - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Errors with version 5.6 (/thread-2506.html) |
Errors with version 5.6 - FredL - 21-09-2020 Have been struggling getting Obi Rope to work. Here's the steps I've taken: Unity version: 2020.1.0b14.4034 OS version: macOS 10.15.6
Parameter name: index System.ThrowHelper.ThrowArgumentOutOfRangeException (System.ExceptionArgument argument, System.ExceptionResource resource) (at <fb001e01371b4adca20013e0ac763896>:0) System.ThrowHelper.ThrowArgumentOutOfRangeException () (at <fb001e01371b4adca20013e0ac763896>:0) Obi.ObiRope.RebuildElementsFromConstraintsInternal () (at Assets/Obi/Scripts/RopeAndRod/Actors/ObiRope.cs:322) Obi.ObiRopeBase.RebuildElementsFromConstraints () (at Assets/Obi/Scripts/RopeAndRod/Actors/ObiRopeBase.cs:67) Obi.ObiRope.LoadBlueprint (Obi.ObiSolver solver) (at Assets/Obi/Scripts/RopeAndRod/Actors/ObiRope.cs:165) Obi.ObiSolver.AddActor (Obi.ObiActor actor) (at Assets/Obi/Scripts/Common/Solver/ObiSolver.cs:1089) Obi.ObiActor.AddToSolver () (at Assets/Obi/Scripts/Common/Actors/ObiActor.cs:312) Obi.ObiRopeEditor.OnInspectorGUI () (at Assets/Obi/Editor/RopeAndRod/ObiRopeEditor.cs:127) UnityEditor.UIElements.InspectorElement+<>c__DisplayClass58_0.<CreateIMGUIInspectorFromEditor>b__0 () (at /Users/builduser/buildslave/unity/build/Editor/Mono/Inspector/InspectorElement.cs:535) UnityEngine.GUIUtilityrocessEvent(Int32, IntPtr, Boolean&) (at /Users/builduser/buildslave/unity/build/Modules/IMGUI/GUIUtility.cs:189) ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index System.ThrowHelper.ThrowArgumentOutOfRangeException (System.ExceptionArgument argument, System.ExceptionResource resource) (at <fb001e01371b4adca20013e0ac763896>:0) System.ThrowHelper.ThrowArgumentOutOfRangeException () (at <fb001e01371b4adca20013e0ac763896>:0) Obi.ObiRope.RebuildElementsFromConstraintsInternal () (at Assets/Obi/Scripts/RopeAndRod/Actors/ObiRope.cs:322) Obi.ObiRopeBase.RebuildElementsFromConstraints () (at Assets/Obi/Scripts/RopeAndRod/Actors/ObiRopeBase.cs:67) Obi.ObiPathSmoother.GenerateSmoothChunks (Obi.ObiRopeBase actor, System.UInt32 smoothingLevels) (at Assets/Obi/Scripts/RopeAndRod/DataStructures/Path/ObiPathSmoother.cs:150) Obi.ObiPathSmoother.Actor_OnInterpolate (Obi.ObiActor actor) (at Assets/Obi/Scripts/RopeAndRod/DataStructures/Path/ObiPathSmoother.cs:61) Obi.ObiActor.Interpolate () (at Assets/Obi/Scripts/Common/Actors/ObiActor.cs:1129) Obi.ObiSolver.Interpolate (System.Single stepTime, System.Single unsimulatedTime) (at Assets/Obi/Scripts/Common/Solver/ObiSolver.cs:1502) Obi.ObiUpdater.Interpolate (System.Single stepDeltaTime, System.Single accumulatedTime) (at Assets/Obi/Scripts/Common/Updaters/ObiUpdater.cs:115) Obi.ObiFixedUpdater.Update () (at Assets/Obi/Scripts/Common/Updaters/ObiFixedUpdater.cs:79) IndexOutOfRangeException: Index was outside the bounds of the array. Obi.ObiRope.RebuildElementsFromConstraintsInternal () (at Assets/Obi/Scripts/RopeAndRod/Actors/ObiRope.cs:304) Obi.ObiRopeBase.RebuildElementsFromConstraints () (at Assets/Obi/Scripts/RopeAndRod/Actors/ObiRopeBase.cs:67) Obi.ObiPathSmoother.GenerateSmoothChunks (Obi.ObiRopeBase actor, System.UInt32 smoothingLevels) (at Assets/Obi/Scripts/RopeAndRod/DataStructures/Path/ObiPathSmoother.cs:150) Obi.ObiPathSmoother.Actor_OnInterpolate (Obi.ObiActor actor) (at Assets/Obi/Scripts/RopeAndRod/DataStructures/Path/ObiPathSmoother.cs:61) Obi.ObiActor.Interpolate () (at Assets/Obi/Scripts/Common/Actors/ObiActor.cs:1129) Obi.ObiSolver.Interpolate (System.Single stepTime, System.Single unsimulatedTime) (at Assets/Obi/Scripts/Common/Solver/ObiSolver.cs:1502) Obi.ObiUpdater.Interpolate (System.Single stepDeltaTime, System.Single accumulatedTime) (at Assets/Obi/Scripts/Common/Updaters/ObiUpdater.cs:115) Obi.ObiFixedUpdater.Update () (at Assets/Obi/Scripts/Common/Updaters/ObiFixedUpdater.cs:79) I took a took at the source quickly, but couldn't see the problem RE: Errors with version 5.6 - josemendez - 22-09-2020 Hi there, This is a bug in Obi. Thanks for reporting this! It should not stop the rope path editor or simulation from working though. The fix is simple: open up ObiRope.cs, and change line 291 (in RebuildElementsFromConstraintsInternal method) to be: if (dc == null || dc.GetBatchCount() < 2) That should do it. Let me know how it goes! RE: Errors with version 5.6 - FredL - 22-09-2020 (22-09-2020, 07:33 AM)josemendez Wrote: Hi there, Fixed, many thanks. |
