obi stitcher softbody - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Softbody (https://obi.virtualmethodstudio.com/forum/forum-12.html) +--- Thread: obi stitcher softbody (/thread-2472.html) |
obi stitcher softbody - tegleg - 05-09-2020 Hi does the obi stitcher work with 2 soft bodies? if it does is there any documentation how to use it? i tried it on the barrel example scene like this, moved 2 barrels close to each other. added the stitcher to the solver and the barrels to the first/second actor. press edit and added stitches, i could see green dotted lines for the stitches. pressed edit to get out of edit mode. press play and fired at the barrels, they are not constrained together. anything i did wrong or does it not work? thanks RE: obi stitcher softbody - josemendez - 06-09-2020 Stitch constraints are globally disabled in that particular scene's solver component, because they're not used. Make sure to enable them, or they will be ignored during simulation. See: http://obi.virtualmethodstudio.com/tutorials/obisolver.html RE: obi stitcher softbody - tegleg - 09-09-2020 thank you it still doesnt work, is this the best way to constrain 2 soft bodies? RE: obi stitcher softbody - josemendez - 09-09-2020 (09-09-2020, 02:34 AM)tegleg Wrote: thank you Hi there, Just tried it and does work for me, this is the best (and currently only) way to constrain 2 softbodies. What Obi version are you using? RE: obi stitcher softbody - tegleg - 09-09-2020 im using the latest version, fresh download and project the other day. i must be missing a step somewhere. please could you produce a document or a video showing how to do it? thank you RE: obi stitcher softbody - josemendez - 09-09-2020 (09-09-2020, 12:44 PM)tegleg Wrote: im using the latest version, fresh download and project the other day. Hi, My bad, I was testing using the development version (5.6). There is a small bug in 5.5 that prevents stitch constraints from working the first time they're enabled. The fix is easy: Open ObiStitcher.cs, then take line 186: Code: inSolver = true; And move it to line 177, at the start of the method. Should look like this: Code: if (!inSolver) The stitcher should work fine now. RE: obi stitcher softbody - tegleg - 09-09-2020 yes that works thank you |
