Can't edit Softbody Surface Blueprint - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Softbody (https://obi.virtualmethodstudio.com/forum/forum-12.html) +--- Thread: Can't edit Softbody Surface Blueprint (/thread-2471.html) |
Can't edit Softbody Surface Blueprint - BARISSI - 05-09-2020 Hi, Trying to follow this tutorial -> http://obi.virtualmethodstudio.com/tutorials/charactersoftbody.html But I am getting stuck where we have to edit the blueprint and paint the particles. I cannot paint anything. The curser circle stays on the screen with an offset to the actual cursor's location. Maybe this could be related to that. Also the look of my edit mode is different than the one on the tutorial. I just see small spheres around. Am I missing out something? Please help. RE: Can't edit Softbody Surface Blueprint - josemendez - 05-09-2020 (05-09-2020, 12:33 AM)BARISSI Wrote: Hi, Hi, make sure you dont have multiple inspector tabs open, as the editor UI will only appear in one of them. Regarding the offset in the cursor, this is a known bug that affects high density (retina-like) screens. Note this is only a visual problem, paint brush interaction stills works fine. We’ve recently fixed it and will provide a patch next monday. |
