Bug / Crash Error Destroy ObiCollider - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Bug / Crash Error Destroy ObiCollider (/thread-2466.html) |
Error Destroy ObiCollider - Chess - 03-09-2020 Hi Jose, I spotted something weird when the ObiCollider are destroyed in my project. I procedurally generate a rope and its blueprint at runtime (similar to your scene RopeGrapplingHook ). Everything looks good and it's working. However, every time when I turn off the play mode, I got this error : ArgumentNullException: Value cannot be null. Parameter name: key System.Collections.Generic.Dictionary`2[TKey,TValue].Remove (TKey key) (at <599589bf4ce248909b8a14cbe4a2034e>:0) Obi.ObiMeshShapeTracker.Destroy () (at Assets/Obi/Scripts/Common/Collisions/ColliderTrackers/Trackers3D/ObiMeshShapeTracker.cs:131) Obi.ObiColliderBase.RemoveCollider () (at Assets/Obi/Scripts/Common/Collisions/ObiColliderBase.cs:216) Obi.ObiColliderBase.OnDestroy () (at Assets/Obi/Scripts/Common/Collisions/ObiColliderBase.cs:276) The issues doesn't appear on all ObiCollider, I've more than 1000 ObiCollider in my scene and this error appears on about 100 of them. So I fixed that by adding an additional check before the Remove in the Destroy method of the ObiMeshShapeTracker class (line 121) : Code: public override void Destroy() Moreover, although my rope is well initialized and works fine, if I turn off the play mode and turn it on again, I get this error : NullReferenceException: Object reference not set to an instance of an object Obi.ObiRopeBlueprint+<Initialize>d__2.MoveNext () (at Assets/Obi/Scripts/RopeAndRod/Blueprints/ObiRopeBlueprint.cs:56) Obi.ObiActorBlueprint+<Generate>d__68.MoveNext () (at Assets/Obi/Scripts/Common/Blueprints/ObiActorBlueprint.cs:300) Obi.ObiActorBlueprint.GenerateImmediate () (at Assets/Obi/Scripts/Common/Blueprints/ObiActorBlueprint.cs:278) Obi.ObiRopeBlueprintBase.OnValidate () (at Assets/Obi/Scripts/RopeAndRod/Blueprints/ObiRopeBlueprintBase.cs:50) I suppose it's could be related to the rope creation at runtime or maybe a memory leak during the rope or blueprint destruction ? Thanks in advance RE: Error Destroy ObiCollider - josemendez - 04-09-2020 Hi there, I could reproduce the first one. It will happen when a MeshCollider whose sharedMesh is null is destroyed. This is a bug in Obi (thanks for finding and reporting it!), and the fix is as easy as checking if the sharedMesh is null before looking for it in the meshDataCache -just like you did- as it's not necessary to reduce the reference count of a mesh that does not exist. However it's pretty unusual to have a collider referencing no mesh, so this might be indicative of a deeper problem in your scene. The second one I could not reproduce, though. The error points to the rope being unable to destroy its first particle group (first control point), but a rope should always have at least 2 control points, this is ensured throughout the code. Can you share how you're initializing the rope at runtime? RE: Error Destroy ObiCollider - Chess - 04-09-2020 Thanks Jose, indeed I've probably something not logic in my scene, I'll take a look ! Finally for the second point, I just tried my code on the last version of Obi (5.5) and I don't have the error. So yes, I think that's is probably an issue with my version of Obi (5.2) or Unity (2019.2). But for technical reasons I prefer to stay on Unity 2019.2, so I will not upgrade to the 5.5 which is tagged 2019.3.1 on the asset store. That's strange because before I didn't have this error, it suddenly appeared. I wonder if my Obi plugin is probably corrupted. I would appreciate it if you could send me the 5.2 version or the last version compatible with Unity 2019.2.7. I will mail you on the Obi support email. Thank you ! |
