Installation Issue Unity 2017.3.0F3 - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Installation Issue Unity 2017.3.0F3 (/thread-246.html) |
Installation Issue Unity 2017.3.0F3 - DemeterDKD - 19-12-2017 I received this error while importing Obi Cloth into my project Assets/Obi/Rendering/ShadowmapExposer.cs(8,8): error CS0108: Warning as Error: `Obi.ShadowmapExposer.light' hides inherited member `UnityEngine.Component.light'. Use the new keyword if hiding was intended Because of this error I cant start my game any more ![]() Any thoughts on how I can fix this? RE: Installation Issue Unity 2017.3.0F3 - josemendez - 20-12-2017 (19-12-2017, 07:52 PM)DemeterDKD Wrote: I received this error while importing Obi Cloth into my project You can safely delete ShadowmapExposer.cs. It is only used in very specific scenarios where you want particle impostors to cast shadows from non-directional lights, when rendering cloth using the ObiParticleRenderer (which I highly doubt you'll ever need). Our next update (3.3) will be checked for compatibility with most recent versions, including 2018.1. RE: Installation Issue Unity 2017.3.0F3 - DemeterDKD - 21-12-2017 (20-12-2017, 10:29 AM)josemendez Wrote: You can safely delete ShadowmapExposer.cs. It is only used in very specific scenarios where you want particle impostors to cast shadows from non-directional lights, when rendering cloth using the ObiParticleRenderer (which I highly doubt you'll ever need). PERFECT!!! Im glad it was an easy fix! Thank you so much, having a blast playing with the settings now!
