'ObiCloth' does not contain a definition for 'VolumeConstraints' - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: 'ObiCloth' does not contain a definition for 'VolumeConstraints' (/thread-2451.html) |
'ObiCloth' does not contain a definition for 'VolumeConstraints' - yeyoya - 27-08-2020 Hey, I've tried to use the code I found on Obi's website to add pressure to my object, but I got the following error message: Assets/_Scripts/Inflator.cs(24,15): error CS1061: 'ObiCloth' does not contain a definition for 'VolumeConstraints' and no accessible extension method 'VolumeConstraints' accepting a first argument of type 'ObiCloth' could be found (are you missing a using directive or an assembly reference?) Here is the code: Code: using UnityEngine; Many thanks RE: 'ObiCloth' does not contain a definition for 'VolumeConstraints' - josemendez - 28-08-2020 Hi there, You're looking at the docs for 3.X/4.X, there's no "VolumeConstraints" property in 5.X. You can now access global constraint properties directly (pressure, compliance, etc), see the API for the ObiCloth class: http://obi.virtualmethodstudio.com/api.html The correct code should be along the lines of: Code: cloth.pressure = <your new pressure> See: http://obi.virtualmethodstudio.com/tutorials/volumeconstraints.html RE: 'ObiCloth' does not contain a definition for 'VolumeConstraints' - yeyoya - 01-09-2020 (28-08-2020, 08:53 AM)josemendez Wrote: Hi there, I must have found an older documentation. It is working now. Many thanks!!! |
