Help Copy properties and groups from one blueprint to another - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Help Copy properties and groups from one blueprint to another (/thread-2438.html) |
Copy properties and groups from one blueprint to another - nexar - 21-08-2020 Hi Jose, I'm writing to you again, because we have this situation: We have an original 3D mesh with blendshapes and its blueprint configured (with its own properties and particle groups). At one point the blendshapes change once, and then we bake the mesh with the updated blendshapes, to have the "updated baked mesh". With this baked mesh we generate its new blueprint, which has exactly the same number of particles as the original blueprint. Code: bakedMesh = new Mesh(); How can we copy each property and particle group from the original blueprint to the new generated blueprint? What is the right way to achieve this at runtime using scripts? How should we go through the list of particles of the original blueprint, to read and copy each property and group? Should we first generate the new blueprint for the updated baked mesh, and then edit the property and group of each particle? We would appreciate your help in doing this. Thanks in advance! PD: Le agradeceremos muchísimo si por favor nos respondiera pronto, pues es lo único que nos falta para terminar el proyecto. RE: Copy properties and groups from one blueprint to another - josemendez - 21-08-2020 Hi! I believe I just answered your original email, check it out and let me know if you have more questions. RE: Copy properties and groups from one blueprint to another - nexar - 22-08-2020 Thank you very much for your rapid response, and for your kind willingness to help us. We have found your response very helpful, as we did not know how to unlock this... We have sent you another e-mail with questions about how to save the generated blueprint in a different file, and about the correct way to reassign the new blueprint to the "SkinnedCloth" component, and force it to be reloaded. Thanks in advance for your help! Best regards! PD: Nuevamente le agradeceremos poder recibir pronto su respuesta, pues esto es lo último que nos falta para terminar. RE: Copy properties and groups from one blueprint to another - jbordas - 31-08-2022 Hi jose , I have the exact same problem right now, would it be possible to get a copy of the information you sent to nexar ? Thank you. RE: Copy properties and groups from one blueprint to another - josemendez - 31-08-2022 (31-08-2022, 08:47 AM)jbordas Wrote: Hi jose , I have the exact same problem right now, would it be possible to get a copy of the information you sent to nexar ? Hi there, Assuming both blueprint have the *exact* same topology (vertex count and triangle connectivity are identical) copying data is just a matter of iterating trough all particle arrays, constraint batches, and optionally particle groups: Code: // Copy particle data, except for positions, orientations and velocities: RE: Copy properties and groups from one blueprint to another - jbordas - 31-08-2022 (31-08-2022, 08:57 AM)josemendez Wrote: Hi there, Thank you very much ! I'll try this out ! |
