Help Burst Safety Checks - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Help Burst Safety Checks (/thread-2429.html) |
Burst Safety Checks - Kristaps - 17-08-2020 Hello, ![]() Thanks for the latest release! You've done an awesome job! Played around with the latest release and stumbled on some errors with Jobs/Burst. Should Burst Safety Checks be enabled or disabled? ( by default they are enabled ) Asking because if they are enabled - I get array index errors and everything breaks! Code: System.IndexOutOfRangeException: Index {0} is out of range of '{1}' Length. P.S. ( If Burst Safety Checks are disabled all works fine ) P.S.S ( This is the full stack ) Code: IndexOutOfRangeException: Index 34 is out of range of '34' Length. RE: Burst Safety Checks - josemendez - 18-08-2020 Hi there! Safety checks should be disabled for performance reasons, but nonetheless there should be no errors with them enabled. Will try to reproduce this and get back to you asap. ![]() RE: Burst Safety Checks - josemendez - 18-08-2020 I've been unable to get this to happen in any the sample scenes, or making my own. Can you provide steps to reproduce this? I have Burst safety checks enabled, synchronous compilation disabled, jobs debugger disabled. RE: Burst Safety Checks - Kristaps - 18-08-2020 Hello! Thanks for looking into this! Will try to make a test scene with repro steps when will be at home! |
