Help Solver.OnParticleCollision not work + mix 3 color - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Help Solver.OnParticleCollision not work + mix 3 color (/thread-2320.html) |
Solver.OnParticleCollision not work + mix 3 color - hungseparate - 18-06-2020 Hi, im working on a project that currently using obi fluid 5.3 1. As i follow tutorial with collision callback, i noticed that solver.OnParticleCollision not work as i expect. - ObiSolver.ObiCollisionEventArgs alway return with count = 0. - I already change emitter A and B with difference phase (1 & 2) still not work 2.Im checking your mixing color scene, i saw that it use field "x" in diffusion data, it running from 0 - 1 and revert. - Is this value update auto by obi ? - I want to mix 3 or more color, how can i use this data to receive infomation i need ? Thanks ! RE: Solver.OnParticleCollision not work + mix 3 color - josemendez - 18-06-2020 1.- solver.OnParticleCollision returns collisions between particles. If you're emitting fluids, you will always get zero contacts as fluid particles do not collide with each other. Fluids use density constraints to try and keep constant local density. If they collided, you'd get granular (sand) simulation instead. From the manual: Quote:Density constraints 2.- Diffusion works by averaging diffusion data between neighboring particles. There's 4 diffusion channels: x,y,z and w. You can use each one to average one "property" of the fluid, which one is up to you. Could be color, viscosity, vorticity, or any other. For instance, the "Raclette" sample scene maps "x" to viscosity, and "y" to surface tension. To mix two colors, you can use a single diffusion channel and lerp (linearly interpolate) between the two colors based on the value of the channel. To mix many colors (3,4,5...), the easiest way is to use the x,y,z diffusion channels to store color r,g,b, and use them directly. This way you can have as many colors as you want. RE: Solver.OnParticleCollision not work + mix 3 color - hungseparate - 18-06-2020 "use the x,y,z diffusion channels to store color r,g,b" As i understand, i need to loop through all particles, get it rgb value, then set it back to userdata ? then other particle will receive this userdata, calculate new color ? I don't really understand this userdata, it store current particle's value ? or store value of particle next to it ? RE: Solver.OnParticleCollision not work + mix 3 color - josemendez - 18-06-2020 All per-particle data arrays (position, velocity, color, userData, etc) store a value for each particle. So userData[i] is the data for particle i, not any of its neighbors. During the simulation, each particle averages its userData with the neighboring particles via density constraints, that's how diffusion is implemented. So all you need to do is set the desired color of each fluid type in the diffusion data (userData) or the blueprint, then at runtime iterate over all particles and set color[i] = userData[i] at the end of every frame. That's all there is to it. Let me know if you need help writing the code for this. RE: Solver.OnParticleCollision not work + mix 3 color - hungseparate - 18-06-2020 I'm not sure if i got it right, but it not working so well ![]() First of all, i using 2 emitters, 2 blueprints Then i put color data into userdata when particle emit Code: private void _actor_OnEmitParticle(ObiEmitter emitter, int particleIndex)After that, i set color in LateUpdate Code: private void LateUpdate()Nvm, i figure it out now. My code is working fine, but color field in "Obi Particle Renderer" component mess it up, after set it back to "White", it look good now ! Btw, thanks for your help, great asset but lack of documents ![]() I think you should update document with these info, that'll be great !
