Help ObiExternalForce - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Help ObiExternalForce (/thread-2302.html) |
ObiExternalForce - hromoyDron - 09-06-2020 Hello! Can't understand how should I use ObiExternalForce I use ObiAmbientForceZone and attach it to the object on scene from where I want this for to apply On the Scene View I see correct force vector. I attach solver to ObiExternalForce. But when I run scene no forces applied to my solvers with emiters. My be I should setting something else except ObiAmbientForceZone? Is there any example? I find only scripting reference: http://obi.virtualmethodstudio.com/docs/class_obi_1_1_obi_ambient_force_zone.html And no info in documentation. RE: ObiExternalForce - josemendez - 09-06-2020 (09-06-2020, 01:48 PM)hromoyDron Wrote: Hello! Atmospheric forces will only affect the fluid if it has non-zero athmospheric drag. The higher you set the drag coefficient, the more fluid will be affected by forces. See: http://obi.virtualmethodstudio.com/tutorials/emittermaterials.html Quote:Athmospheric drag must be greater than zero for fluid to be affected by force zones (wind). |
