whats wrong with this cloth? - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: whats wrong with this cloth? (/thread-2263.html) |
whats wrong with this cloth? - lloydhuang - 23-05-2020 this is a lady with obi cloth(skinned). cloth mesh setting: [attachment=695] when i run the scene, the cloth goes to the air~ [attachment=696] this is solver setting, i tried to use all initial settings, or close all options, or enlarge the particle numbers, problem not solved. [attachment=697] this is cloth setting, also, i tried to close everything, tried to modify particle radius,etc, problem not solved. [attachment=698] PS: This is happened in several of my models. In one of it , I rebind it many times using different ways, and the problem solved, but i dont know why. PS2: for the first image, i noticed the notes: Closed: False. Is this the reason? What is closed means? RE: whats wrong with this cloth? - josemendez - 23-05-2020 (23-05-2020, 07:49 AM)lloydhuang Wrote: this is a lady with obi cloth(skinned). cloth mesh setting: Hi, Your mesh is non-manifold (as the warning in the first screenshot is telling you). Non-manifold meshes are not supported by Obi. See: http://obi.virtualmethodstudio.com/tutorials/clothsetup.html "Closed" means that the mesh completely encloses a volume and has no holes in it, like a balloon. This is not an issue, it only means that volume constraints will not be available (because air can't be contained inside the mesh). RE: whats wrong with this cloth? - lloydhuang - 23-05-2020 (23-05-2020, 10:17 AM)josemendez Wrote: Hi, Thank you! |
