Unfix particles via scripting - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Unfix particles via scripting (/thread-225.html) |
Unfix particles via scripting - mbbmbbmm - 04-11-2017 Ok, so in order to fix a particle and make it move with the transform i should set the inverse Mass of the particle to zero (making the mass infinite I think). This works nicely. But how do I achieve the opposite, how can I unfix the particle again? If I give it back it's cached inverse mass it doesn't do anything - it doesn't react to gravity etc... Ah nevermind I got it! actor.PushDataToSolver(ParticleData.INV_MASSES); was required. One more question. When I set up the cloth, i set the mass for all particles to 0.1. Shouldn't the inverse masses all be 10? Because when I cache them they have different values, some have 4760.332, some have 14281, some have 9520.665... What i s going on there? Thank you! |
