Help Fluid dipping effect. Is it possible? - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Help Fluid dipping effect. Is it possible? (/thread-2222.html) |
Fluid dipping effect. Is it possible? - nRonko - 04-05-2020 Hi everyone! I am looking for a solution that will create the effect of spraying paint on water and mixing. Is it possible with OBI Fluid? An example here: Youtube video example RE: Fluid dipping effect. Is it possible? - josemendez - 05-05-2020 (04-05-2020, 09:14 PM)nRonko Wrote: Hi everyone! Nope, a particle-based fluid simulator is not a good choice for this at all. You're not interested in simulating the entire volume of fluid, only the surface. Moreover, you want an easy way to convert the result to a texture, which is a grid-like structure. so 2D grid-based fluid simulators are a much better choice. After the paint has been mixed, a good old texture projector can be used to transfer it to the surface of an object. Cocuy comes to mind: https://assetstore.unity.com/packages/tools/particles-effects/cocuy-the-fluid-simulator-33564. Note I'm not the developer of Cocuy, not advocating for it. Simply using it as an example of what I mean. RE: Fluid dipping effect. Is it possible? - nRonko - 05-05-2020 (05-05-2020, 08:02 AM)josemendez Wrote: Nope, a particle-based fluid simulator is not a good choice for this at all. You're not interested in simulating the entire volume of fluid, only the surface. Moreover, you want an easy way to convert the result to a texture, which is a grid-like structure. Thank you, Josemendez. I will look at Cocuy asset |
