Help unrigged cloth animation with rigged character avatar - Printable Version
+--- Thread: Help unrigged cloth animation with rigged character avatar (/thread-2212.html)
unrigged cloth animation with rigged character avatar - Bhavesh - 01-05-2020
How can i animate without rigged separate cloth with rigged avatar? Where cloth i can change dynamically. so avatar will be same for other cloth also. Please help i have tried with rigged cloth with rigged avatar but cloth animation not looks realistic. Please help.
RE: unrigged cloth animation with rigged character avatar - josemendez - 01-05-2020
(01-05-2020, 01:22 PM)Bhavesh Wrote: How can i animate without rigged separate cloth with rigged avatar? Where cloth i can change dynamically. so avatar will be same for other cloth also. Please help i have tried with rigged cloth with rigged avatar but cloth animation not looks realistic. Please help.
This is not possible to do in realtime in the general case, no matter what engine you use. For an unrigged cloth to work with trigged character, you'd have to rely on collision detection which is unfeasible.
Character cloth must be rigged to the same skeleton as the character.
RE: unrigged cloth animation with rigged character avatar - Bhavesh - 01-05-2020
(01-05-2020, 01:28 PM)josemendez Wrote: Hi,
This is not possible to do in real time in the general case, no matter what engine you use. For an unrigged cloth to work with trigged character, you'd have to rely on collision detection which is unfeasible.
Do i need to copy or sync bone of the cloth with character bone while animating character ? Here i am attaching images link below and its output with rigged cloth and avatar.
https://ibb.co/nMhhkt8
https://ibb.co/8dyk6ZR
https://ibb.co/M8XjSt4
https://ibb.co/6XGQ08d
https://ibb.co/MkyRYKx
https://ibb.co/qkjb3hv
https://ibb.co/Zd8xXZZ
https://ibb.co/qxk3hrq
Output:
https://vimeo.com/user114374867/review/413945509/0200b91ccc
