Non stretchable Rope - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Non stretchable Rope (/thread-2125.html) Pages:
1
2
RE: Non stretchable Rope - Ronnie - 28-03-2020 (28-03-2020, 02:06 PM)josemendez Wrote: If you require any kind of two-way interaction with Unity rigidbodies (and you do, since you're attaching to one using a dynamic attachment), and need to use multiple substeps (and you seem to do) make sure to enable Substep Unity physics in the updater as the manual indicates: No change it is just makimg rope tighter but not keeping the rope in olace and straight instead it is moving here there on its own RE: Non stretchable Rope - josemendez - 28-03-2020 (28-03-2020, 02:09 PM)Ronnie Wrote: No change it is just makimg rope tighter but not keeping the rope in olace and straight instead it is moving here there on its own Without a more in depth description of your setup, all I can do is guess.... Maybe you attached the rope to inside the collider? This will of couse cause weird behavior, as the collider is pushing the rope outside and the attachmebt pushing it inside. The solution would be to set both to the same phase, as explained here: http://obi.virtualmethodstudio.com/tutorials/pinconstraints.html |
