Bug / Crash Doesn't build for latest XCode (11.4) - Printable Version
+--- Thread: Bug / Crash Doesn't build for latest XCode (11.4) (/thread-2124.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
RE: Doesn't build for latest XCode (11.4) - Yaskorama - 26-06-2020
(24-06-2020, 08:20 AM)josemendez Wrote: Well, looks like I was wrong. XCode 12 beta 1 does seem to contain the fix, according to Apple's response a few hours ago to the bug report. Haven't tested it yet.
I will do so later today. Fingers crossed! Gran sonrisa
[Image: d3KtOZj.png]
Is there any news about the situation? In addition, I would appreciate if you could send the Obi rope running in 11.3.1 version.
RE: Doesn't build for latest XCode (11.4) - josemendez - 30-06-2020
Hi all,
Just tested the Xcode 12 beta, and I can confirm: the linker bug is fixed. Linking finishes successfully and it runs fine. Here's a screenie of the successful build/link/run:
[Image: KeB9dIM.png]
So, XCode 12 should work as intended for Obi builds once again, using any Obi version.
If you're stuck with XCode 11.4 or 11.5 for now, revert to 11.3.1 and use a Obi version with bitcode compatibility (5.1, 5.2 or 5.4).
RE: Doesn't build for latest XCode (11.4) - Warren - 16-07-2020
How about Xcode 11.6?
RE: Doesn't build for latest XCode (11.4) - josemendez - 16-07-2020
(16-07-2020, 07:40 AM)Warren Wrote: How about Xcode 11.6?
Haven't tried, but Apple specifically referred to XCode 12 beta 1 being the one containing the fix, so I'd assume 11.6 does not contain it, unless they back ported:
Quote:Please verify this issue with the Xcode 12 beta 1 and update your bug report with your results by logging into https://feedbackassistant.apple.com/ or by using the Feedback Assistant app.
Xcode 12 beta 1 (12A6159)
https://developer.apple.com/download/
Posted Date: June 22nd, 2020
RE: Doesn't build for latest XCode (11.4) - davidsedrakyan - 19-07-2020
is this fixed now on new obi versions?
RE: Doesn't build for latest XCode (11.4) - josemendez - 20-07-2020
(19-07-2020, 10:50 PM)davidsedrakyan Wrote: is this fixed now on new obi versions?
This is not a bug in Obi, but in XCode. It has been fixed in XCode 12 beta 1. Check my previous post in this thread.
RE: Doesn't build for latest XCode (11.4) - Hypercasual_dev - 22-07-2020
Hey guys,
I'm buidling a game using cloud build, and I tried different versions of xcode there, including 11.3.1 and 10.3.
Build crashes anyway. Triste
Could you help, please?
Logs for both
259: [color=#ffffff]❌[/color];  ld: in /BUILD_PATH/24play.gasstationjam.default-ios/temp20200722-6417-gk9my1/Libraries/Obi/Plugins/iOS/libOni.a(Oni.o), could not parse object file /BUILD_PATH/24play.gasstationjam.default-ios/temp20200722-6417-gk9my1/Libraries/Obi/Plugins/iOS/libOni.a(Oni.o): 'Invalid bitcode version (Producer: '1103.0.32.29.0_0' Reader: '1100.0.33.17_0')', using libLTO version 'LLVM version 11.0.0, (clang-1100.0.33.17)' for architecture armv7
260: [color=#ffffff]❌[/color];  clang: error: linker command failed with exit code 1 (use -v to see invocation)
Thanks in advance!
RE: Doesn't build for latest XCode (11.4) - maceb - 04-08-2020
(16-07-2020, 07:43 AM)josemendez Wrote: Haven't tried, but Apple specifically referred to XCode 12 beta 1 being the one containing the fix, so I'd assume 11.6 does not contain it, unless they back ported:
Hello Jose, could I please get the version of Obi Softbody that works with Xcode 11.3? I'm getting this issue using the latest version of Obi Softbody and Xcode 11.6. My email is macebarihi@gmail.com. Currently downloading Xcode 12 but thought I'd ask anyway in case it doesn't work for me.
Thanks a lot Jose, your asset is wonderful!
RE: Doesn't build for latest XCode (11.4) - josemendez - 05-08-2020
(04-08-2020, 11:07 PM)maceb Wrote: Hello Jose, could I please get the version of Obi Softbody that works with Xcode 11.3? I'm getting this issue using the latest version of Obi Softbody and Xcode 11.6. My email is macebarihi@gmail.com. Currently downloading Xcode 12 but thought I'd ask anyway in case it doesn't work for me.
Hi Maceb,
Just sent you an email. cheers!
RE: Doesn't build for latest XCode (11.4) - GiftedMamba - 13-08-2020
Hi, Josemendez! As I untderstand, I can't build project with any xCode, starting from 11.4. Also Apple doesn't allow to push in the store project builded with 12 version, because it is a beta.
It looks like I need to use older version of Obi Rope, right? If so, how can I get it?
