Help Precise cutting - Printable Version
+--- Thread: Help Precise cutting (/thread-2087.html)
Precise cutting - dotyou - 08-03-2020
Hey there,
I bought the asset yesterday mainly due to the fact you can tear the cloth. I was wondering if you are able to make precise cuts (example; if you were to use a knife to cut a straight line) with the asset. If it is possible, could you point me in the right direction? Also is there documentation for this asset?
Thank you,
dy
RE: Precise cutting - josemendez - 08-03-2020
(08-03-2020, 04:42 PM)dotyou Wrote: Hey there,
Thank you,
dy
“Precise” cuts are not supported, because they would require runtime remeshing which is a really expensive operation. Only tearing along existing mesh edges is supported, like in most cloth simulators.
The manual/docs can be found here:
