Export and/or freeze a simulated object. - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Export and/or freeze a simulated object. (/thread-1613.html) |
Export and/or freeze a simulated object. - lukeh1980 - 09-01-2020 Hi There, is it possible to run the cloth simulation and then export the object as it is at rest? In other words if I wanted to create a static sheet object I would create a simple square mesh, let obi cloth simulate the sheet resting on a bed, then export the sheet as if it was modeled that way? Does that make sense, is that possible? Thanks, Luke RE: Export and/or freeze a simulated object. - josemendez - 09-01-2020 (09-01-2020, 07:48 PM)lukeh1980 Wrote: Hi There, is it possible to run the cloth simulation and then export the object as it is at rest? In other words if I wanted to create a static sheet object I would create a simple square mesh, let obi cloth simulate the sheet resting on a bed, then export the sheet as if it was modeled that way? Does that make sense, is that possible? Yep. Simply click the "BakeMesh" button in the cloth renderer component. This will save the current state of the cloth as a new mesh asset. Only works for regular and tearable cloth, not for skinned cloth. RE: Export and/or freeze a simulated object. - lukeh1980 - 10-01-2020 (09-01-2020, 07:59 PM)josemendez Wrote: Yep. Simply click the "BakeMesh" button in the cloth renderer component. This will save the current state of the cloth as a new mesh asset. Sounds, good! Sounds likeĀ I probably couldn't use it to bake character clothing that doesn't necessarily need to be constantly simulated because that would be over a skinned mesh? I know you have some performance data but is there a demo so I can see how it runs on an older or slower pc/laptop? Thanks! |
