Skinned Cloth with Proxy - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Skinned Cloth with Proxy (/thread-1566.html) Pages:
1
2
RE: Skinned Cloth with Proxy - khos85 - 26-07-2021 (26-07-2021, 08:41 AM)josemendez Wrote: Hi, RE: Skinned Cloth with Proxy - josemendez - 27-07-2021 Hi there, Code: Thank you! I was able to solve the issue, my high res mesh was not marked as read/write, now the mesh/cloth simulation works for highres/proxy. Unity already checks if any code is accessing a non-readable mesh and throws an error to the console to warn you about this. In the future we might place a warning in the inspector UI directly, just like we do with blueprints. Code: But FPS is quite low (20fps), hmm not sure how to fix that, yet. Any tips would be welcomed. There's lot of possible reasons for performance issues. Best advice I can give is take a look at the profiler (specially if you're using the Burst backend). This will give you detailed information about what is time being spent on. Tweaking constraint iterations and substeps is a good place to start, as these largely define the quality/performance ratio of the simulation. Iterations can be adjusted on a per-solver basis: http://obi.virtualmethodstudio.com/manual/6.2/obisolver.html And substeps are adjusted on a per-updater basis: http://obi.virtualmethodstudio.com/manual/6.2/updaters.html The manual contains an in-depth explanation of how the engine works and how iterations/substeps affect it: http://obi.virtualmethodstudio.com/manual/6.2/convergence.html A quite common reason for bad performance in any physics engine (including Obi) is death spiraling. This happens when the physics loop can't keep up with rendering, and Unity updates physics multiple times per frame. Check if FixedUpdate() is being called more than once per frame (the profiler will tell you this), then increase your timestep if necessary. kind regards, |
