Particle Editor Not showing up - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Particle Editor Not showing up (/thread-1433.html) |
Particle Editor Not showing up - ccBLI - 18-10-2019 Hello, I'm having a problem with a newly set up Cloth object. After initializing correctly, when I hit the edit particles button nothing shows up, neither the window or the particles on the mesh. The samples for the plugin work fine and the particle editor works in the Character Cloth demo. (18-10-2019, 06:54 PM)ccBLI Wrote: Hello, Aha, there are errors. This is the error I'm getting: NullReferenceException: Object reference not set to an instance of an object Obi.ObiClothEditor.UpdateParticleEditorInformation () (at Assets/Obi/Editor/ObiClothEditor.cs:96) Obi.ObiParticleActorEditor.OnSceneGUI () (at Assets/Obi/Editor/ObiParticleActorEditor.cs:247) System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at <7ba07f088431485bb722f3b3373e87ee>:0) Rethrow as TargetInvocationException: Exception has been thrown by the target of an invocation. System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at <7ba07f088431485bb722f3b3373e87ee>:0) System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) (at <7ba07f088431485bb722f3b3373e87ee>:0) UnityEditor.SceneView.CallOnSceneGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:2837) UnityEditor.SceneView.HandleSelectionAndOnSceneGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:2126) UnityEditor.SceneView.OnGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:1987) System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at <7ba07f088431485bb722f3b3373e87ee>:0) Rethrow as TargetInvocationException: Exception has been thrown by the target of an invocation. System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at <7ba07f088431485bb722f3b3373e87ee>:0) System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) (at <7ba07f088431485bb722f3b3373e87ee>:0) UnityEditor.HostView.Invoke (System.String methodName, System.Object obj) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:342) UnityEditor.HostView.Invoke (System.String methodName) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:336) UnityEditor.HostView.InvokeOnGUI (UnityEngine.Rect onGUIPosition, UnityEngine.Rect viewRect) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:310) UnityEditor.DockArea.DrawView (UnityEngine.Rect viewRect, UnityEngine.Rect dockAreaRect, System.Boolean customBorder, System.Boolean floatingWindow, System.Boolean isBottomTab) (at C:/buildslave/unity/build/Editor/Mono/GUI/DockArea.cs:361) UnityEditor.DockArea.OldOnGUI () (at C:/buildslave/unity/build/Editor/Mono/GUI/DockArea.cs:320) UnityEngine.Experimental.UIElements.IMGUIContainer.DoOnGUI (UnityEngine.Event evt, UnityEngine.Matrix4x4 worldTransform, UnityEngine.Rect clippingRect, System.Boolean isComputingLayout) (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:266) UnityEngine.Experimental.UIElements.IMGUIContainer.HandleIMGUIEvent (UnityEngine.Event e, UnityEngine.Matrix4x4 worldTransform, UnityEngine.Rect clippingRect) (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:438) UnityEngine.Experimental.UIElements.IMGUIContainer.HandleIMGUIEvent () (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:412) UnityEngine.Experimental.UIElements.ImmediateStylePainter.DrawImmediate (System.Action callback) (at C:/buildslave/unity/build/Modules/UIElements/ImmediateStylePainter.cs:113) UnityEngine.Experimental.UIElements.IMGUIContainer.DoRepaint (UnityEngine.Experimental.UIElements.IStylePainter painter) (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:98) UnityEngine.Experimental.UIElements.VisualElement.Repaint (UnityEngine.Experimental.UIElements.IStylePainter painter) (at C:/buildslave/unity/build/Modules/UIElements/VisualElement.cs:862) UnityEngine.Experimental.UIElements.VisualTreeRepaintUpdater.PaintSubTree (UnityEngine.Experimental.UIElements.VisualElement root, UnityEngine.Matrix4x4 offset, System.Boolean shouldClip, System.Boolean shouldCache, UnityEngine.Rect currentGlobalClip) (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeRepaintUpdater.cs:310) UnityEngine.Experimental.UIElements.VisualTreeRepaintUpdater.PaintSubTreeChildren (UnityEngine.Experimental.UIElements.VisualElement root, UnityEngine.Matrix4x4 offset, System.Boolean shouldClip, System.Boolean shouldCache, UnityEngine.Rect textureClip) (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeRepaintUpdater.cs:328) UnityEngine.Experimental.UIElements.VisualTreeRepaintUpdater.PaintSubTree (UnityEngine.Experimental.UIElements.VisualElement root, UnityEngine.Matrix4x4 offset, System.Boolean shouldClip, System.Boolean shouldCache, UnityEngine.Rect currentGlobalClip) (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeRepaintUpdater.cs:314) UnityEngine.Experimental.UIElements.VisualTreeRepaintUpdater.Update () (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeRepaintUpdater.cs:35) UnityEngine.Experimental.UIElements.VisualTreeUpdater.UpdateVisualTree () (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeUpdater.cs:70) UnityEngine.Experimental.UIElements.Panel.Repaint (UnityEngine.Event e) (at C:/buildslave/unity/build/Modules/UIElements/Panel.cs:507) UnityEngine.Experimental.UIElements.UIElementsUtility.DoDispatch (UnityEngine.Experimental.UIElements.BaseVisualElementPanel panel) (at C:/buildslave/unity/build/Modules/UIElements/UIElementsUtility.cs:230) UnityEngine.Experimental.UIElements.UIElementsUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr) (at C:/buildslave/unity/build/Modules/UIElements/UIElementsUtility.cs:68) UnityEngine.GUIUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr) (at C:/buildslave/unity/build/Modules/IMGUI/GUIUtility.cs:179) RE: Particle Editor Not showing up - wbvdw - 23-10-2019 (18-10-2019, 06:54 PM)ccBLI Wrote: Hello, I was having the same issues and noticed a warning that my mesh didn't have `Read/Write Enabled` checked. Checking this box in the mesh inspector solved the issue for me. |
