Oni Contacts - is there a way to extend the data? - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Oni Contacts - is there a way to extend the data? (/thread-1376.html) |
Oni Contacts - is there a way to extend the data? - TimLewis - 19-09-2019 Hi there! I'm trying to extend the Oni Contacts data struct to include a further variable [attachment=406] I'm wondering if there's a way to populate this when the Contact data gets set? I have a BitMask variable that is in ObiEmitter that denotes what FluidType the fluid counts as: [attachment=407] And another FluidType variable which denotes what fluid containers accept (ie. wine glasses accept wine fluid). I'm hoping there's a way to do this, as I'm trying to parallelise, into jobs, the logic to sort the contacts into containers - so I don't have the option of grabbing the particle emitter from Obi Solver. Thanks in advance for all your help. Tim RE: Oni Contacts - is there a way to extend the data? - josemendez - 05-10-2019 (19-09-2019, 03:30 PM)TimLewis Wrote: Hi there! Hi, You should not modify the contact struct, as it the C++ size of things assumes a certain memory layout (hence the StructLayout attribute). Modifying it or changing its size will result in undefined behavior --> most likely an instant crash if you're lucky, or memory corruption. There's currently no way to extend contacts with user-defined data. |
