Adding Pin Constraint in Unity 2017.1.0f3 - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Adding Pin Constraint in Unity 2017.1.0f3 (/thread-127.html) |
Adding Pin Constraint in Unity 2017.1.0f3 - echer - 12-09-2017 Trying to add a pin constraint and it will not allow me to add an object to the Pinned To: Parameter... it acts like nothing is in the scene at all... I have created a cube and added the Rigid Body to it RE: Adding Pin Constraint in Unity 2017.1.0f3 - josemendez - 12-09-2017 (12-09-2017, 05:11 PM)echer Wrote: Trying to add a pin constraint and it will not allow me to add an object to the Pinned To: Parameter... it acts like nothing is in the scene at all... 3.2 Introduces a new collision and pin constraints system. See: http://obi.virtualmethodstudio.com/tutorials/collisions.html You have to add a ObiCollider component to your cube. Then, drop this component into the "Pinned To:" slot of the pin constraint. cheers! |
