Small chain - Printable Version
+--- Thread: Small chain (/thread-1236.html)
Small chain - Evgenius - 21-06-2019
Hello!
I need to make a small chain ~30cm, with small links. I used default chain links from sample scenes, but if I scale links or chain itself, the gap between the links appears, like there's a missing link. Resolution set to 1.
RE: Small chain - josemendez - 21-06-2019
(21-06-2019, 08:32 AM)Evgenius Wrote: Hello!
One link is added per rope segment (the space between two consecutive particles). If with a resolution of 1 the amount of particles is not large enough, reduce the rope's "thickness". A resolution of 1 will make the distance between consecutive particles equal to the thickness value, as explained in the manual:
http://obi.virtualmethodstudio.com/tutorials/ropeparameters.html
